Done!
Great job @Nas, I’ve missed that file when looking for PPPoE modifications.
I’ve opened an issue:
http://dev.nethserver.org/issues/3240
@GG_jr, could you update from nethserver-testing, remove the template-custom and verify that everything works as expected? Thanks.
See the above issue for details about the package.
Hi Filippo,
I made the following steps:
- The template-custom was removed from /etc/e-smith/
- “Block HTTP and HTTPS ports” was disabled (no errors).
- NethServer was rebooted (no errors).
- Verified “line 31” from /etc/e-smith/templates/etc/shorewall/rules/90squid (ok).
- Enabled “Block HTTP and HTTPS ports” for “Transparent” mode (no errors).
- Changed “Transparent” mode to “Transparent with SSL” mode (no errors).
- Disabled “Block HTTP and HTTPS ports” for “Transparent with SSL” mode (no errors).
- Enabled “Block HTTP and HTTPS ports” for “Transparent with SSL” mode (no errors).
- Changed “Transparent with SSL” mode to “Transparent” mode (no errors).
- Reconfigured PPPoE (no errors).
- Verified access to the Internet (ok).
END TEST
- Posted test result (no errors).
Gabriel
PS
All above steps was made also last night.
