I struggled to configure openproject (docker all in one image) with the reverse proxy.
OP is configured to run in http mode.
Error message : [Error 422] Unable to verify Cross-Site Request Forgery token.
In OP logs : (https://example.com) didn't match request.base_url (http://example.com)
Solution :
Add the following line in /etc/httpd/conf.d/virtualhosts.conf
(in the section corresponding to the https reverse proxy configuration):
RequestHeader set X_FORWARDED_PROTO 'https'
(That needs to be templated of course)
I believe that should be at least a setting in the UI. What do you think ?
