HeloHost . FQDN hostname used by Postfix when connecting to other MTAs
Where would I configure this? If it works it would be the easiest solution, thanks for suggesting also an alternative with custom template, but I am willing to try this variable first. Though, I did not understand yet, where to set it?
Thanks, it looks good. The result is as expected that postfix uses the desired hostname.
PS. How can I mark the problem as solved, Just edit the title and put [solved] or how should that be done in this forum?
PPS. Thanks for your fast and competent help, and keep up the good work
