Changes done, but error is still there. The same on RED IP also on GREEN IP.
You are able to reach the SOGo login screen?
The error shows up after supplying the login credentials?
No, right after accessing IP/SOGo
And still no error shows up in sogo.log?
There is another issue (strange):
I think is better to reinstall NS.
Yeah, I thinking about going back to NS6.8
and trying NS7 only in virtual. But new functions on NS7 are great and I wnat them
I think that was a typo: sogo.service (incorrect) instead of sogod.service (correct)
No, you can use NS7.
First, try to reinstall.
I have tried with SOGo and it worked.
My issue was the following: I have installed Samba AD and I could not login in SOGo (I think, by default, the settings are for LDAP) but I could reach the login page.
Good point!
I don’t know if it is sogo.service:
[root@server1 ~]# systemctl restart sogo.service
Failed to restart sogo.service: Unit sogo.service failed to load: No such file or directory.
No. it is sogod, but I don’t think that’s the problem (you already showed it was running).
[root@server1 ~]# systemctl restart sogod.service
If you would like to try the following:
Edit /etc/httpd/conf/httpd.conf and replace LogLevel warn with LogLevel debug
Also, at the end of the file append this line: ProxyBadHeader Ignore
Edit /etc/httpd/conf.d/ssl.conf and replace LogLevel warn with LogLevel debug
Then restart apache: apachectl restart (or systemctl restart httpd)
Wait some seconds and verify it is started: apachectl status (or systemctl status httpd)
Then try to login to SOGo and report errors during that timeframe; logs:
- /var/log/sogo/sogo.log
- /var/log/httpd/error_log
- /var/log/httpd/ssl_error_log
There are also some interesting lines in /etc/httpd/nethserver.d/00default:443.vhost
Additionally, if the client computer has curl, you can report the output of:
curl -kvIL https://192.168.3.1/SOGo/
OK. I can see login page. After login I see this error:
And errors and logs:
[root@server1 ~]# apachectl status
- httpd.service - The Apache HTTP Server
Loaded: loaded (/usr/lib/systemd/system/httpd.service; enabled; vendor preset: disabled)
Active: active (running) since Wed 2016-08-17 13:56:29 CEST; 8s ago
Docs: man:httpd(8)
man:apachectl(8)
Process: 25702 ExecStop=/bin/kill -WINCH ${MAINPID} (code=exited, status=0/SUCCESS)
Main PID: 25707 (httpd)
Status: “Processing requests…”
CGroup: /system.slice/httpd.service
|-25707 /usr/sbin/httpd -DFOREGROUND
|-25709 /usr/sbin/httpd -DFOREGROUND
|-25710 /usr/sbin/httpd -DFOREGROUND
|-25711 /usr/sbin/httpd -DFOREGROUND
|-25712 /usr/sbin/httpd -DFOREGROUND
`-25713 /usr/sbin/httpd -DFOREGROUND
Aug 17 13:56:29 server1.maxcomputers.sk systemd[1]: Starting The Apache HTTP Server…
Aug 17 13:56:29 server1.maxcomputers.sk httpd[25707]: [Wed Aug 17 13:56:29.851963 2016] [proxy:warn] [pid 25707] AH01146: Ignoring parameter ‘retry=60’ for worker 'http://127.0.0.1:20000/SOG...orker sharing
Aug 17 13:56:29 server1.maxcomputers.sk httpd[25707]: [Wed Aug 17 13:56:29.852051 2016] [proxy:warn] [pid 25707] AH01146: Ignoring parameter ‘connectiontimeout=5’ for worker 'http://127.0.0…orker sharing
Aug 17 13:56:29 server1.maxcomputers.sk httpd[25707]: [Wed Aug 17 13:56:29.852056 2016] [proxy:warn] [pid 25707] AH01146: Ignoring parameter ‘timeout=360’ for worker 'http://127.0.0.1:20000/...orker sharing
Aug 17 13:56:29 server1.maxcomputers.sk systemd[1]: Started The Apache HTTP Server.
Hint: Some lines were ellipsized, use -l to show in full.
[root@server1 ~]# curl -kvIL https://192.168.3.1/SOGo/
- About to connect() to 192.168.3.1 port 443 (#0)
- Trying 192.168.3.1…
- Connected to 192.168.3.1 (192.168.3.1) port 443 (#0)
- Initializing NSS with certpath: sql:/etc/pki/nssdb
- skipping SSL peer certificate verification
- SSL connection using TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
- Server certificate:
subject: L=Martin,C=SK,OU=Main,OID.2.5.29.17=*.maxcomputers.sk,E=root@server1.maxcomputers.sk,ST=Slovakia,O=MAXcomputers,CN=NethServer -
start date: Aug 15 06:38:06 2016 GMT -
expire date: Aug 13 06:38:06 2026 GMT -
common name: NethServer -
issuer: L=Martin,C=SK,OU=Main,OID.2.5.29.17=*.maxcomputers.sk,E=root@server1.maxcomputers.sk,ST=Slovakia,O=MAXcomputers,CN=NethServer
HEAD /SOGo/ HTTP/1.1
User-Agent: curl/7.29.0
Host: 192.168.3.1
Accept: /
< HTTP/1.1 302 Found
HTTP/1.1 302 Found
< Date: Wed, 17 Aug 2016 12:03:52 GMT
< Server: Apache/2.4.6 (CentOS) OpenSSL/1.0.1e-fips PHP/5.4.16
< Content-Type: text/plain; charset=UTF-8
< Location: /SOGo/index
- Connection #0 to host 192.168.3.1 left intact
- Issue another request to this URL: ‘https://192.168.3.1/SOGo/index’
- Found bundle for host 192.168.3.1: 0x222fd70
- Re-using existing connection! (#0) with host 192.168.3.1
HEAD /SOGo/index HTTP/1.1
Host: 192.168.3.1
Accept: /
HTTP/1.1 302 Found
< Content-Type: text/plain; charset=utf-8
< Location: /SOGo/index/
- Issue another request to this URL: ‘https://192.168.3.1/SOGo/index/’
HEAD /SOGo/index/ HTTP/1.1
Host: 192.168.3.1
Accept: /
< HTTP/1.1 200 OK
HTTP/1.1 200 OK
< Date: Wed, 17 Aug 2016 12:03:53 GMT
< Content-Length: 2217
< Content-Type: text/html; charset=utf-8
Aug 17 14:03:07 sogod [25724]: <0x0x7f154ca06f40[SOGoCache]> Cache cleanup interval set every 300.000000 seconds
Aug 17 14:03:07 sogod [25724]: <0x0x7f154ca06f40[SOGoCache]> Using host(s) ‘127.0.0.1’ as server(s)
Aug 17 14:03:07 sogod [25724]: [WARN] <0x0x7f154d05c6b0[SOGoWebDAVAclManager]> entry ‘{DAV:}write’ already exists in DAV permissions table
Aug 17 14:03:07 sogod [25724]: [WARN] <0x0x7f154d05c6b0[SOGoWebDAVAclManager]> entry ‘{DAV:}write-properties’ already exists in DAV permissions table
Aug 17 14:03:07 sogod [25724]: [WARN] <0x0x7f154d05c6b0[SOGoWebDAVAclManager]> entry ‘{DAV:}write-content’ already exists in DAV permissions table
Aug 17 14:03:07 sogod [25724]: 192.168.3.169 “REPORT /SOGo/dav/maxcomputers/Calendar/personal/ HTTP/1.1” 207 125/188 0.067 - - 2M
Aug 17 14:03:52 sogod [25724]: 192.168.3.1 “HEAD /SOGo/ HTTP/1.1” 302 0/0 0.002 - - 12K
Aug 17 14:03:53 sogod [25724]: 192.168.3.1 “HEAD /SOGo/index HTTP/1.1” 302 0/0 0.016 - - 976K
Aug 17 14:03:53 sogod [25724]: 192.168.3.1 “HEAD /SOGo/index/ HTTP/1.1” 200 2217/0 0.018 - - 696K
/var/log/httpd/error_log - nothing new
[Wed Aug 17 13:57:05.468759 2016] [proxy_http:error] [pid 25717] (20014)Internal error: [client 192.168.3.169:35709] AH01102: error reading status line from remote server 127.0.0.1:20000, referer: https://$
[Wed Aug 17 13:57:05.601222 2016] [proxy_http:error] [pid 25713] (20014)Internal error: [client 192.168.3.169:35710] AH01102: error reading status line from remote server 127.0.0.1:20000, referer: https://$
[Wed Aug 17 13:57:05.601297 2016] [proxy:error] [pid 25713] [client 192.168.3.169:35710] AH00898: Error reading from remote server returned by /SOGo/so/maxcomputers/Mail/view, referer: https://192.168.3.1/$
Can you create a new test user and try to login with it?
New user created, but now, I don’t know why, I’m not able to see login screen again.
new in /var/log/httpd/error_log
[Wed Aug 17 15:45:41.902467 2016] [core:info] [pid 25707] AH00096: removed PID file /run/httpd/httpd.pid (pid=25707)
[Wed Aug 17 15:45:41.902515 2016] [mpm_prefork:notice] [pid 25707] AH00170: caught SIGWINCH, shutting down gracefully
[Wed Aug 17 15:45:41.902606 2016] [core:debug] [pid 25828] unixd.c(426): (9)Bad file descriptor: AH02178: apr_socket_accept failed for inactive listener
[Wed Aug 17 15:45:43.028407 2016] [suexec:notice] [pid 27007] AH01232: suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Wed Aug 17 15:45:43.028585 2016] [ssl:debug] [pid 27007] ssl_engine_pphrase.c(181): AH02199: SSL not enabled on vhost server1.maxcomputers.sk:80, skipping SSL setup
[Wed Aug 17 15:45:43.028857 2016] [ssl:debug] [pid 27007] ssl_engine_pphrase.c(239): AH02202: Init: Read server certificate from ‘/etc/pki/tls/certs/localhost.crt’
[Wed Aug 17 15:45:43.029058 2016] [ssl:debug] [pid 27007] ssl_engine_pphrase.c(181): AH02199: SSL not enabled on vhost server1.maxcomputers.sk:80, skipping SSL setup
[Wed Aug 17 15:45:43.029233 2016] [ssl:debug] [pid 27007] ssl_engine_pphrase.c(239): AH02202: Init: Read server certificate from ‘/etc/pki/tls/certs/localhost.crt’
[Wed Aug 17 15:45:43.029382 2016] [ssl:info] [pid 27007] AH01887: Init: Initializing (virtual) servers for SSL
[Wed Aug 17 15:45:43.030509 2016] [ssl:debug] [pid 27007] ssl_engine_init.c(1482): Init: SSL server IP/port overlap: server1.maxcomputers.sk:443 (/etc/httpd/nethserver.d/00default:443.vhost:16) vs. server1$
[Wed Aug 17 15:45:43.030522 2016] [ssl:warn] [pid 27007] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Wed Aug 17 15:45:43.030536 2016] [ssl:info] [pid 27007] AH01876: mod_ssl/2.4.6 compiled against Server: Apache/2.4.6, Library: OpenSSL/1.0.1e
[Wed Aug 17 15:45:43.074288 2016] [proxy:warn] [pid 27007] AH01146: Ignoring parameter ‘retry=60’ for worker ‘http://127.0.0.1:20000/SOGo’ because of worker sharing
[Wed Aug 17 15:45:43.074316 2016] [proxy:warn] [pid 27007] AH01146: Ignoring parameter ‘connectiontimeout=5’ for worker ‘http://127.0.0.1:20000/SOGo’ because of worker sharing
[Wed Aug 17 15:45:43.074320 2016] [proxy:warn] [pid 27007] AH01146: Ignoring parameter ‘timeout=360’ for worker ‘http://127.0.0.1:20000/SOGo’ because of worker sharing
[Wed Aug 17 15:45:43.075407 2016] [auth_digest:notice] [pid 27007] AH01757: generating secret for digest authentication …
[Wed Aug 17 15:45:43.075436 2016] [auth_digest:debug] [pid 27007] mod_auth_digest.c(250): AH01759: done
[Wed Aug 17 15:45:43.076241 2016] [slotmem_shm:debug] [pid 27007] mod_slotmem_shm.c(448): AH02301: attach looking for /run/httpd/slotmem-shm-mod_heartmonitor.shm
[Wed Aug 17 15:45:43.076260 2016] [lbmethod_heartbeat:notice] [pid 27007] AH02282: No slotmem from mod_heartmonitor
[Wed Aug 17 15:45:43.076398 2016] [ssl:debug] [pid 27007] ssl_engine_pphrase.c(181): AH02199: SSL not enabled on vhost server1.maxcomputers.sk:80, skipping SSL setup
[Wed Aug 17 15:45:43.076599 2016] [ssl:debug] [pid 27007] ssl_engine_pphrase.c(239): AH02202: Init: Read server certificate from ‘/etc/pki/tls/certs/localhost.crt’
[Wed Aug 17 15:45:43.076763 2016] [ssl:debug] [pid 27007] ssl_engine_pphrase.c(181): AH02199: SSL not enabled on vhost server1.maxcomputers.sk:80, skipping SSL setup
[Wed Aug 17 15:45:43.076896 2016] [ssl:debug] [pid 27007] ssl_engine_pphrase.c(239): AH02202: Init: Read server certificate from ‘/etc/pki/tls/certs/localhost.crt’
[Wed Aug 17 15:45:43.077022 2016] [socache_shmcb:debug] [pid 27007] mod_socache_shmcb.c(391): AH00821: shmcb_init allocated 512000 bytes of shared memory
[Wed Aug 17 15:45:43.077028 2016] [socache_shmcb:debug] [pid 27007] mod_socache_shmcb.c(407): AH00822: for 511912 bytes (512000 including header), recommending 32 subcaches, 88 indexes each
[Wed Aug 17 15:45:43.077031 2016] [socache_shmcb:debug] [pid 27007] mod_socache_shmcb.c(440): AH00824: shmcb_init_memory choices follow
[Wed Aug 17 15:45:43.077034 2016] [socache_shmcb:debug] [pid 27007] mod_socache_shmcb.c(442): AH00825: subcache_num = 32
[Wed Aug 17 15:45:43.077037 2016] [socache_shmcb:debug] [pid 27007] mod_socache_shmcb.c(444): AH00826: subcache_size = 15992
[Wed Aug 17 15:45:43.077040 2016] [socache_shmcb:debug] [pid 27007] mod_socache_shmcb.c(446): AH00827: subcache_data_offset = 2128
[Wed Aug 17 15:45:43.077042 2016] [socache_shmcb:debug] [pid 27007] mod_socache_shmcb.c(448): AH00828: subcache_data_size = 13864
[Wed Aug 17 15:45:43.077045 2016] [socache_shmcb:debug] [pid 27007] mod_socache_shmcb.c(450): AH00829: index_num = 88
[Wed Aug 17 15:45:43.077144 2016] [socache_shmcb:info] [pid 27007] AH00830: Shared memory socache initialised
[Wed Aug 17 15:45:43.077148 2016] [ssl:info] [pid 27007] AH01887: Init: Initializing (virtual) servers for SSL
[Wed Aug 17 15:45:43.078055 2016] [ssl:debug] [pid 27007] ssl_engine_init.c(1482): Init: SSL server IP/port overlap: server1.maxcomputers.sk:443 (/etc/httpd/nethserver.d/00default:443.vhost:16) vs. server1$
[Wed Aug 17 15:45:43.078064 2016] [ssl:warn] [pid 27007] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Wed Aug 17 15:45:43.078074 2016] [ssl:info] [pid 27007] AH01876: mod_ssl/2.4.6 compiled against Server: Apache/2.4.6, Library: OpenSSL/1.0.1e
[Wed Aug 17 15:45:43.144734 2016] [proxy:debug] [pid 27009] proxy_util.c(1843): AH00925: initializing worker proxy:reverse shared
[Wed Aug 17 15:45:43.144790 2016] [proxy:debug] [pid 27009] proxy_util.c(1885): AH00927: initializing worker proxy:reverse local
[Wed Aug 17 15:45:43.144843 2016] [proxy:debug] [pid 27009] proxy_util.c(1936): AH00931: initialized single connection worker in child 27009 for ()
[Wed Aug 17 15:45:43.147309 2016] [proxy:debug] [pid 27010] proxy_util.c(1843): AH00925: initializing worker proxy:reverse shared
[Wed Aug 17 15:45:43.147364 2016] [proxy:debug] [pid 27010] proxy_util.c(1885): AH00927: initializing worker proxy:reverse local
[Wed Aug 17 15:45:43.147410 2016] [proxy:debug] [pid 27010] proxy_util.c(1936): AH00931: initialized single connection worker in child 27010 for ()
[Wed Aug 17 15:45:43.149867 2016] [proxy:debug] [pid 27011] proxy_util.c(1843): AH00925: initializing worker proxy:reverse shared
[Wed Aug 17 15:45:43.149920 2016] [proxy:debug] [pid 27011] proxy_util.c(1885): AH00927: initializing worker proxy:reverse local
[Wed Aug 17 15:45:43.149966 2016] [proxy:debug] [pid 27011] proxy_util.c(1936): AH00931: initialized single connection worker in child 27011 for (*)
[Wed Aug 17 15:45:43.151743 2016] [mpm_prefork:notice] [pid 27007] AH00163: Apache/2.4.6 (CentOS) OpenSSL/1.0.1e-fips PHP/5.4.16 configured – resuming normal operations
[Wed Aug 17 15:45:43.151790 2016] [mpm_prefork:info] [pid 27007] AH00164: Server built: Jul 18 2016 15:30:14
new in /var/log/sogo/sogo.log
ug 17 15:44:46 sogod [24097]: <0x0x7f154ccb28f0[WOWatchDogChild]> (terminated due to signal 6)
Aug 17 15:44:46 sogod [24097]: <0x0x7f154ccb28f0[WOWatchDogChild]> avoiding to respawn child before 2016-08-17 15:44:51 +0200
Aug 17 15:44:47 sogod [24097]: <0x0x7f154ca0b4c0[WOWatchDog]> child spawned with pid 26895
Aug 17 15:44:48 sogod [26895]: <0x0x7f154ca904f0[SOGoCache]> Cache cleanup interval set every 300.000000 seconds
Aug 17 15:44:48 sogod [26895]: <0x0x7f154ca904f0[SOGoCache]> Using host(s) ‘127.0.0.1’ as server(s)
EXCEPTION: <NSException: 0x7f154d1591f0> NAME:NSInvalidArgumentException REASON:init with obj and key arrays of different sizes INFO:(null)
Aug 17 15:44:48 sogod [24097]: [ERROR] <0x0x7f154ca0b4c0[WOWatchDog]> No child available to handle incoming request!
Aug 17 15:44:48 sogod [24097]: <0x0x7f154ccb26b0[WOWatchDogChild]> child 26895 exited
Aug 17 15:44:48 sogod [24097]: <0x0x7f154ccb26b0[WOWatchDogChild]> (terminated due to signal 6)
Aug 17 15:44:48 sogod [24097]: <0x0x7f154ccb26b0[WOWatchDogChild]> avoiding to respawn child before 2016-08-17 15:44:52 +0200
Aug 17 15:44:49 sogod [24097]: [ERROR] <0x0x7f154ca0b4c0[WOWatchDog]> No child available to handle incoming request!
Aug 17 15:44:49 sogod [24097]: <0x0x7f154ca0b4c0[WOWatchDog]> child spawned with pid 26901
Aug 17 15:44:49 sogod [26901]: <0x0x7f154ca904f0[SOGoCache]> Cache cleanup interval set every 300.000000 seconds
Aug 17 15:44:49 sogod [26901]: <0x0x7f154ca904f0[SOGoCache]> Using host(s) ‘127.0.0.1’ as server(s)
Aug 17 15:44:50 sogod [24097]: <0x0x7f154ccd7fb0[WOWatchDogChild]> child 26901 exited
Aug 17 15:44:50 sogod [24097]: <0x0x7f154ccd7fb0[WOWatchDogChild]> (terminated due to signal 6)
Aug 17 15:44:50 sogod [24097]: <0x0x7f154ccd7fb0[WOWatchDogChild]> avoiding to respawn child before 2016-08-17 15:44:54 +0200
Aug 17 15:44:51 sogod [24097]: <0x0x7f154ca0b4c0[WOWatchDog]> child spawned with pid 26904
Aug 17 15:44:52 sogod [24097]: <0x0x7f154ca0b4c0[WOWatchDog]> child spawned with pid 26907
Aug 17 15:44:52 sogod [26904]: <0x0x7f154ca3e430[SOGoCache]> Cache cleanup interval set every 300.000000 seconds
Aug 17 15:44:52 sogod [26904]: <0x0x7f154ca3e430[SOGoCache]> Using host(s) ‘127.0.0.1’ as server(s)
EXCEPTION: <NSException: 0x7f154d1590e0> NAME:NSInvalidArgumentException REASON:init with obj and key arrays of different sizes INFO:(null)
Aug 17 15:44:53 sogod [24097]: <0x0x7f154ccb28f0[WOWatchDogChild]> child 26904 exited
Aug 17 15:44:53 sogod [24097]: <0x0x7f154ccb28f0[WOWatchDogChild]> (terminated due to signal 6)
Aug 17 15:44:53 sogod [24097]: <0x0x7f154ccb28f0[WOWatchDogChild]> avoiding to respawn child before 2016-08-17 15:44:56 +0200
Aug 17 15:44:55 sogod [24097]: <0x0x7f154ca0b4c0[WOWatchDog]> child spawned with pid 26910
Aug 17 15:44:56 sogod [24097]: <0x0x7f154ca0b4c0[WOWatchDog]> child spawned with pid 26913
Aug 17 15:46:00 sogod [26913]: <0x0x7f154ca904d0[SOGoCache]> Cache cleanup interval set every 300.000000 seconds
Aug 17 15:46:00 sogod [26913]: <0x0x7f154ca904d0[SOGoCache]> Using host(s) ‘127.0.0.1’ as server(s)
EXCEPTION: <NSException: 0x7f154d159060> NAME:NSInvalidArgumentException REASON:init with obj and key arrays of different sizes INFO:(null)
Aug 17 15:46:00 sogod [24097]: <0x0x7f154ccb28f0[WOWatchDogChild]> child 26913 exited
Aug 17 15:46:00 sogod [24097]: <0x0x7f154ccb28f0[WOWatchDogChild]> (terminated due to signal 6)
Aug 17 15:46:00 sogod [24097]: <0x0x7f154ca0b4c0[WOWatchDog]> child spawned with pid 27017
Aug 17 15:48:11 sogod [27017]: <0x0x7f154ca4bac0[SOGoCache]> Cache cleanup interval set every 300.000000 seconds
Aug 17 15:48:11 sogod [27017]: <0x0x7f154ca4bac0[SOGoCache]> Using host(s) ‘127.0.0.1’ as server(s)
Aug 17 15:48:11 sogod [24097]: <0x0x7f154ccb28f0[WOWatchDogChild]> child 27017 exited
Aug 17 15:48:11 sogod [24097]: <0x0x7f154ccb28f0[WOWatchDogChild]> (terminated due to signal 6)
Aug 17 15:48:11 sogod [24097]: <0x0x7f154ca0b4c0[WOWatchDog]> child spawned with pid 27023
new in /var/log/httpd/ssl_error_log
[Wed Aug 17 15:44:23.478041 2016] [proxy_http:error] [pid 25709] (20014)Internal error: [client 192.168.3.169:45636] AH01102: error reading status line from remote server 127.0.0.1:20000
[Wed Aug 17 15:44:23.645362 2016] [proxy_http:error] [pid 25712] (20014)Internal error: [client 192.168.3.169:45637] AH01102: error reading status line from remote server 127.0.0.1:20000
[Wed Aug 17 15:44:23.645425 2016] [proxy:error] [pid 25712] [client 192.168.3.169:45637] AH00898: Error reading from remote server returned by /SOGo/so/maxcomputers/Mail/view
[Wed Aug 17 15:44:25.780285 2016] [proxy_http:error] [pid 25712] (20014)Internal error: [client 192.168.3.169:45637] AH01102: error reading status line from remote server 127.0.0.1:20000
[Wed Aug 17 15:44:25.886936 2016] [proxy_http:error] [pid 25713] (20014)Internal error: [client 192.168.3.169:45644] AH01102: error reading status line from remote server 127.0.0.1:20000
[Wed Aug 17 15:44:25.886991 2016] [proxy:error] [pid 25713] [client 192.168.3.169:45644] AH00898: Error reading from remote server returned by /SOGo/so/maxcomputers/Mail/view
[Wed Aug 17 15:44:29.837164 2016] [proxy_http:error] [pid 25713] (20014)Internal error: [client 192.168.3.169:45644] AH01102: error reading status line from remote server 127.0.0.1:20000
[Wed Aug 17 15:44:29.948227 2016] [proxy_http:error] [pid 25710] (20014)Internal error: [client 192.168.3.169:45649] AH01102: error reading status line from remote server 127.0.0.1:20000
[Wed Aug 17 15:44:29.948296 2016] [proxy:error] [pid 25710] [client 192.168.3.169:45649] AH00898: Error reading from remote server returned by /SOGo/so/maxcomputers/Mail/view
[Wed Aug 17 15:44:32.473350 2016] [proxy_http:error] [pid 25710] (20014)Internal error: [client 192.168.3.169:45649] AH01102: error reading status line from remote server 127.0.0.1:20000, referer: https://$
[Wed Aug 17 15:44:32.611939 2016] [proxy_http:error] [pid 25825] (20014)Internal error: [client 192.168.3.169:45651] AH01102: error reading status line from remote server 127.0.0.1:20000, referer: https://$
[Wed Aug 17 15:44:32.612007 2016] [proxy:error] [pid 25825] [client 192.168.3.169:45651] AH00898: Error reading from remote server returned by /SOGo/so/maxcomputers/Mail/view, referer: https://192.168.3.1/$
[Wed Aug 17 15:44:37.876565 2016] [proxy_http:error] [pid 25717] (20014)Internal error: [client 192.168.3.169:45683] AH01102: error reading status line from remote server 127.0.0.1:20000
[Wed Aug 17 15:44:37.876623 2016] [proxy:error] [pid 25717] [client 192.168.3.169:45683] AH00898: Error reading from remote server returned by /SOGo/
[Wed Aug 17 15:44:40.154851 2016] [proxy_http:error] [pid 25717] (20014)Internal error: [client 192.168.3.169:45683] AH01102: error reading status line from remote server 127.0.0.1:20000
[Wed Aug 17 15:44:40.232139 2016] [proxy_http:error] [pid 25710] (20014)Internal error: [client 192.168.3.169:45688] AH01102: error reading status line from remote server 127.0.0.1:20000
[Wed Aug 17 15:44:40.232196 2016] [proxy:error] [pid 25710] [client 192.168.3.169:45688] AH00898: Error reading from remote server returned by /SOGo/
[Wed Aug 17 15:44:41.367450 2016] [proxy_http:error] [pid 25710] (20014)Internal error: [client 192.168.3.169:45688] AH01102: error reading status line from remote server 127.0.0.1:20000
[Wed Aug 17 15:44:41.485603 2016] [proxy_http:error] [pid 25828] (20014)Internal error: [client 192.168.3.169:45691] AH01102: error reading status line from remote server 127.0.0.1:20000
[Wed Aug 17 15:44:41.485666 2016] [proxy:error] [pid 25828] [client 192.168.3.169:45691] AH00898: Error reading from remote server returned by /SOGo/
[Wed Aug 17 15:44:42.910272 2016] [proxy_http:error] [pid 25711] (20014)Internal error: [client 192.168.3.169:45696] AH01102: error reading status line from remote server 127.0.0.1:20000
[Wed Aug 17 15:44:42.910332 2016] [proxy:error] [pid 25711] [client 192.168.3.169:45696] AH00898: Error reading from remote server returned by /SOGo/
[Wed Aug 17 15:44:45.045318 2016] [proxy_http:error] [pid 25717] (20014)Internal error: [client 192.168.3.169:45698] AH01102: error reading status line from remote server 127.0.0.1:20000
[Wed Aug 17 15:44:45.045375 2016] [proxy:error] [pid 25717] [client 192.168.3.169:45698] AH00898: Error reading from remote server returned by /SOGo/
[Wed Aug 17 15:44:46.502309 2016] [proxy_http:error] [pid 25826] (20014)Internal error: [client 192.168.3.169:45700] AH01102: error reading status line from remote server 127.0.0.1:20000
[Wed Aug 17 15:44:46.502367 2016] [proxy:error] [pid 25826] [client 192.168.3.169:45700] AH00898: Error reading from remote server returned by /SOGo/
[Wed Aug 17 15:44:48.503468 2016] [proxy_http:error] [pid 25826] (20014)Internal error: [client 192.168.3.169:45700] AH01102: error reading status line from remote server 127.0.0.1:20000
[Wed Aug 17 15:44:50.048609 2016] [proxy_http:error] [pid 25827] (20014)Internal error: [client 192.168.3.169:45716] AH01102: error reading status line from remote server 127.0.0.1:20000
[Wed Aug 17 15:44:50.048689 2016] [proxy:error] [pid 25827] [client 192.168.3.169:45716] AH00898: Error reading from remote server returned by /SOGo/
[Wed Aug 17 15:44:53.029972 2016] [proxy_http:error] [pid 25710] (20014)Internal error: [client 192.168.3.169:45724] AH01102: error reading status line from remote server 127.0.0.1:20000
[Wed Aug 17 15:44:53.030052 2016] [proxy:error] [pid 25710] [client 192.168.3.169:45724] AH00898: Error reading from remote server returned by /SOGo/
[Wed Aug 17 15:45:43.028596 2016] [ssl:info] [pid 27007] AH02200: Loading certificate & private key of SSL-aware server ‘server1.maxcomputers.sk:443’
[Wed Aug 17 15:45:43.029026 2016] [ssl:debug] [pid 27007] ssl_engine_pphrase.c(506): AH02249: unencrypted RSA private key - pass phrase not required
[Wed Aug 17 15:45:43.029391 2016] [ssl:info] [pid 27007] AH01914: Configuring server server1.maxcomputers.sk:443 for SSL protocol
[Wed Aug 17 15:45:43.029666 2016] [ssl:debug] [pid 27007] ssl_engine_init.c(406): AH01893: Configuring TLS extension handling
[Wed Aug 17 15:45:43.029677 2016] [ssl:debug] [pid 27007] ssl_engine_init.c(917): AH02232: Configuring RSA server certificate
[Wed Aug 17 15:45:43.029811 2016] [ssl:warn] [pid 27007] AH01906: RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Wed Aug 17 15:45:43.029899 2016] [ssl:debug] [pid 27007] ssl_util_ssl.c(489): AH02412: [server1.maxcomputers.sk:443] Cert does not match for name ‘server1.maxcomputers.sk’ [subject: L=Martin,C=SK,OU=Main,$
[Wed Aug 17 15:45:43.029908 2016] [ssl:warn] [pid 27007] AH01909: RSA certificate configured for server1.maxcomputers.sk:443 does NOT include an ID which matches the server name
[Wed Aug 17 15:45:43.029913 2016] [ssl:debug] [pid 27007] ssl_engine_init.c(972): AH02236: Configuring RSA server private key
[Wed Aug 17 15:45:43.030351 2016] [ssl:warn] [pid 27007] AH01906: RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Wed Aug 17 15:45:43.030367 2016] [ssl:warn] [pid 27007] AH01909: RSA certificate configured for server1.maxcomputers.sk:443 does NOT include an ID which matches the server name
[Wed Aug 17 15:45:43.076404 2016] [ssl:info] [pid 27007] AH02200: Loading certificate & private key of SSL-aware server ‘server1.maxcomputers.sk:443’
[Wed Aug 17 15:45:43.076738 2016] [ssl:debug] [pid 27007] ssl_engine_pphrase.c(506): AH02249: unencrypted RSA private key - pass phrase not required
[Wed Aug 17 15:45:43.077153 2016] [ssl:info] [pid 27007] AH01914: Configuring server server1.maxcomputers.sk:443 for SSL protocol
[Wed Aug 17 15:45:43.077379 2016] [ssl:debug] [pid 27007] ssl_engine_init.c(406): AH01893: Configuring TLS extension handling
[Wed Aug 17 15:45:43.077388 2016] [ssl:debug] [pid 27007] ssl_engine_init.c(917): AH02232: Configuring RSA server certificate
[Wed Aug 17 15:45:43.077487 2016] [ssl:warn] [pid 27007] AH01906: RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Wed Aug 17 15:45:43.077548 2016] [ssl:debug] [pid 27007] ssl_util_ssl.c(489): AH02412: [server1.maxcomputers.sk:443] Cert does not match for name ‘server1.maxcomputers.sk’ [subject: L=Martin,C=SK,OU=Main,$
[Wed Aug 17 15:45:43.077555 2016] [ssl:warn] [pid 27007] AH01909: RSA certificate configured for server1.maxcomputers.sk:443 does NOT include an ID which matches the server name
[Wed Aug 17 15:45:43.077558 2016] [ssl:debug] [pid 27007] ssl_engine_init.c(972): AH02236: Configuring RSA server private key
[Wed Aug 17 15:45:43.077915 2016] [ssl:warn] [pid 27007] AH01906: RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Wed Aug 17 15:45:43.077933 2016] [ssl:warn] [pid 27007] AH01909: RSA certificate configured for server1.maxcomputers.sk:443 does NOT include an ID which matches the server name
[Wed Aug 17 15:46:00.598847 2016] [proxy_http:error] [pid 27012] (20014)Internal error: [client 192.168.3.169:45824] AH01102: error reading status line from remote server 127.0.0.1:20000
[Wed Aug 17 15:46:00.598916 2016] [proxy:error] [pid 27012] [client 192.168.3.169:45824] AH00898: Error reading from remote server returned by /SOGo/
[Wed Aug 17 15:48:11.109027 2016] [proxy_http:error] [pid 27012] (20014)Internal error: [client 192.168.3.169:45962] AH01102: error reading status line from remote server 127.0.0.1:20000
[Wed Aug 17 15:48:11.109087 2016] [proxy:error] [pid 27012] [client 192.168.3.169:45962] AH00898: Error reading from remote server returned by /SOGo/
For testing I have installed WebTop and everything is working with WebTop… but I still want SOGo
OK. @pelo, @GG_jr and @mark_nl reported an upstream bug regarding a missing locale parameter in SOGo.
SOGo version in NethForge repository is 3.0.2 and the bug was fixed on higher versions.
If you (or your browser) are using your regional language, other than english, a quick fix could be:
sed -i "s/}/ NSAMPMDesignation = (AM, PM);\\n}/" /usr/lib64/GNUstep/SOGo/MainUI.SOGo/Resources/{Icelandic,NorwegianBokmal,NorwegianNynorsk,Slovak,Swedish}.lproj/Locale
Thank you guys. You are great
