I have a problem …
How can I change the directory that has not been created ??
The following message I get when I want my account back up and restore manually.
[root@opentree ~]# sogo-tool backup /root/test ALL
2015-04-07 17:31:16.645 sogo-tool[2830] ERROR(+[GCSFolderManager defaultFolderManager]): default ‘OCSFolderInfoURL’ is not configured.
<0x0x22294f8[SOGoUserManager]> No authentication sources defined - nobody will be able to login. Check your defaults.
2015-04-07 17:31:16.696 sogo-tool[2830] ERROR(+[GCSFolderManager defaultFolderManager]): default ‘OCSFolderInfoURL’ is not configured.
<0x0x2210348[SOGoCache]> Cache cleanup interval set every 300.000000 seconds
<0x0x2210348[SOGoCache]> Using host(s) ‘localhost’ as server(s)
2015-04-07 17:31:16.701 sogo-tool[2830] user ‘ALL’ unknown
Thanks!
