NethServer Version: last one
Module: sogo groupware
thumderbird 60.3.1
sogo inverse connector 60
hello all,
In a fresh installed nethserver can’t connect thunderbird to calendar and contacts with sogo inverse connector.
I created a user firstuser@example.com and shared its contacts and calendars with all authenticated users, everyone can do anything on them.
I then created another one user test@example.com that I would to be able to insert and read firstuser contacts and calendar
Accessing the web interface with test credential I can subscribe contacts shared by firstuser and read, insert new and modify existing ones.
The problem is that Sogo inverse connector gives me no errors and it seems to connect but in thunderbird I don’t see contacts or calendars updates.
Can anyone help?
BR
Stefano Gatto
