We are going to release SOGo and mainly the migration from NS7 to NS8, we need tests to make it strong and find bugs
two tests are welcome, think to enable the NethForge repository
case 1: simple installation on a NS8, no risks, simple
case 2, much more fun, install SOGo on a NS7, create some email, some calendars, contacts and migrate it to NS8…with much more fun you can try a scenario with a multi node migration, account provider on one node, SOGo on another
please test all features, ActiveSync, caldav, carddav
of course, the first step of migration is to connect NS8 to the remote LDAP account provider of NS7, then the last step of migration is to migrate the whole account provider of NS7 to NS8
How ever now evaluating NS8 with (Samba) AD, mail and SOGo.
Installation of all of the above, including SOGo, went flawlessly
Installation went flawlessly, unfortunately due to my own mistake can’t get a valid Let’s Encrypt certificate right now so testing AES wont work right now. (One of the pit falls however was my ns8 configuration was requesting a certificate for it’s own hostname and I did not realize it did… So now stuck with error 429: 5 failed requests in an hour)
Great work and I will continue testing tomorrow!
On first glance a cosmetic remark : it shows “Roundcube” in some massages:
$ git grep -n Roundcube
ui/public/i18n/en/translation.json:34: "instance_configuration": "Configure Roundcube",
ui/public/i18n/en/translation.json:37: "mail_server_is_not_valid": "This mail server cannot be used by Roundcube webmail",
Yes very old version on debian…updated each 6 months in ubuntu. I went to archlinux because the community works to provide the version
Hovewer i could have compiled it myself on debian I succeed but i preferred to not go that way
I run a Arch Linux arm instance in my own build media-render for years with out a problem. It is a roiling distro so you just need to keep it up to date: cron does that for me.
I a container this is not an issue, so would not worry to much. Arch Linux is mature, the only unstable part is it is bleeding edge.
