NethServer Version: 7.8.2003
Module: SOGo
when an email arrives in Outlook 2019, in Activesync mode, the message that has the read receipt does not prompt. Via web, on the other hand, a read confirmation is regularly requested.
thanks
Module: SOGo
thanks
Did you ask on sogo community about that? It doesn’t seem a NethServer issue
If you use imap it works?
If not, please have a look at
File - Options - E-Mail - Tracking
at your Outlook, there you can change the options how to work with read receipts.
Yes, in imap it works.
You could try if it works with thunderbird and active sync, so you know if the problem is outlook or sogo.
Thunderbird as activesync with some extensions supports sync of contacts, tasks and calendar but not mail. I can’t take the test.
You’re right, but what is about an android or apple device?
With Android and iOS it does not work with Activesync and Imap
Ok, this looks like a sogo problem.
@support_team
Has somebody the chance to test this?
@AndreLinux
Did you post it at SOGo Forum?
Yes, but no answer
Could you please post the link here?
They replied a short time ago
