SOGo problems with signatures and search
NethServer Version: 7.9.2009
Module: SOGo
Since last update of nethserver-sogo some things are changed.
  • if you try to seek in inbox a special string the search box shows white font on white underground
    in SOGo bug list this is known since April … and perhaps solution there.
  • now it is not possible to edit email signature - OK button is grayed - nothing to save …
    Hope someone have an idea - I not found solutions
    Thanks !
This is addressed in sogo 5.1.1, we are on 5.1.0, so we could consider to move to sogo 5.1.1
Unable to locate the OK button you are referring to; can you make a screen shot?
As a workaround: Following this I’m able to switch signatures.
yum update sogo\* sope\* --enablerepo=nethforge-testing
testers are welcome
Please try to edit email signature…
made it ---- > the same 2 problems ?!?
Oke now I get which button you mean, it’s a bit green-ish. However the OK-bottun works for me .
EDIT it is mandatory to fill in a Full Name and Email (address):
Does it not work for you?
Here the quick-search box is working properly (ie black on withe):
and in the SOGo changelog it is reported to be fixed:
https://www.sogo.nu/bugs/view.php?id=5291
Can you be a bit more specific which problem(s) you still have?
I think something went wrong. Please have a look at your version, is it 5.1.1? You can find it at the settings.
For me the problem with the search field was fixed with the update. The signature works before and after the update, but like @mark_nl said, the OK button is light green, so with wrong colours at your display it could look grey, did you try to click it?
Which browser do you use? Do you have some settings at your client loke “high contrast”?
Hello,
it’s SOGo 5.1.1 and of course I clicked at the OK button - but nothing is done.
I think there is a problem with rights …
It’s not possible to change the signature of admin too.
I know this … but in my SOGo 5.1.1 I cannot see the letters in the search field. I only can see it if I mark this field.
I try it with the browsers Firefox, MS-Edge and Vivaldi
Sorry, can not reproduce tried now with an local AD count provider.
can change the signature of the admin user,
can create a second identity for the admin user with an other signature (NOTE: filling in a Full Name and Email are mandatory)
the quick-search box is black on white
which account provider do you use?
A long-shot: empty the browser-cache …
  1. Thank you very much Mark - this solved the problem “white on white”
  1. Some years ago I had an analog problem … and now I can remember !
    It is an HTML-Signature ! - To edit this signature first you have to change to source code
    then edit source code -> then back to HTML code -> then OK -> then disk symbol
    • already ready :slight_smile:
