SOGo Problem after update
After update to 7.4 final release SOGo would not load, Login page is there, and i can login but after that the page stays blank.
and i get alot of these lines in sogo.log :
Nov 06 07:01:40 sogod [3139]: [ERROR] <0x0x55ff54b113f0[SOGoSQLUserProfile]> failed to acquire channel for URL: mysql://sogo:bM7V1clWkPCZRnyx@localhost/sogo/sogo_user_profile
Downgrading nethserver-sogo-1.6.12-1.ns7.sdl.noarch to nethserver-sogo-1.6.11-1.ns7.noarch
solved it for now, but i will have to upgrade someday i guess
Uhm, does anyone try SOGo on 7.4 yet?
@mark_nl @robb @gg_jr @hucky @rowihei bruno @gerald_fs @miko10 @transocean @asl @frx44 @flatspin @giordy @Pascal_Michard @andreadb @GOB @kisaacs @wclemo @m.traeumner
For me it works fine.
I’m testing sogo from nightly repo and my own custom fragments and I have no issues so far
I installed a fresh NS 7.3 a few days ago and then I did all the upgrades available, so ended up with 7.4. I tested Sogo event triggered emails first off all, but so far everything is fine.
If it happens again check mysql service is running
everything works smooth and good at my side
Thank you everyone for looking into this so soon. I will retry the update.
Retried update and working, thank you all
I installed a fresh NS 7.4 on two different servers. One as the domain controller, ad.domain.lan, pdс.domain.lan and second mail.domain.lan, as the mail server. I entered into the domain, and installed the sogo. When I authenticate users, with not a simple password, on the mail server, I get an error:
Nov 08 09:03:52 sogod [6466]: <0x0x55debf2967e0[LDAPSource]> <NSException: 0x55debf580410> NAME:LDAPException REASON:operation bind failed: Strong(er) authentication required (0x8) INFO:{"error_code" = 8; login = "samaccountname=b00,dc=ad,dc=domain,dc=lan"; }
Nov 08 09:03:52 sogod [6466]: [ERROR] <0x0x55debf390d50[LDAPSource]> Could not bind to the LDAP server ldap://nsdc-pdc.ad.domain.lan (389) using the bind DN: DOMAIN\MAIL$
Nov 08 09:03:52 sogod [6466]: [ERROR] <0x0x55debf390d50[LDAPSource]> <NSException: 0x55debef8cd60> NAME:LDAPException REASON:operation bind failed: Strong(er) authentication required (0x8) INFO:{"error_code" = 8; login = "DOMAIN\\MAIL$"; }
Nov 08 09:03:52 sogod [6466]: SOGoRootPage Login from '172.16.0.33' for user 'b00' might not have worked - password policy: 65535 grace: -1 expire: -1 bound: 0
Nov 08 09:03:52 sogod [6466]: 172.16.0.33 "POST /SOGo/connect HTTP/1.1" 403 34/80 0.096 - - 740K
With the outgoing version 7.3, everything worked well.
Hi @somebody,
seems like you have this problem with ldap(s):
It could be also a problem with some symbols at the passwords.
Please have a look here
Login to Sogo with active directory user - #10 by m.traeumner
