VPN? With OpenVPN? Which use TLS just like WebTop, Sogo, and NextCloud?
Ok… your fence, your rules
Yes, you see well. These are my strict rules to protect the system.
@stephdl Can you give the setting a clear name? For example, “Allow access from the red interface”.
Can a translation be assigned to this?
In the meantime, an update has been received in the official repository for nethserver-sogo and I can confirm that the setup works.
Thank you for your help.
@giacomo Thank you for your advice.
I think this could be useful for someone else and knowing the SOGo solution I don’t think it should be a problem. I hope it can be solved.
I think this will only make Nethserver more flexible to use and configure.
If only I need the solution, I will use this solution as I have done with SOGo so far.
