steve
(steve)
21
@mrmarkuz Thank you for your answer.
I removed SOGo 2.2.0 and when the repo was updated and version 2.1.0 was released again, I installed it.
I had it set up so that users logged in with their full email address instead of their username and I had to reset this.
What could have happened during the SOGo 2.2.0 update that caused the SOGo website to crash?
Will someone fix it and release a new version?
steve
(steve)
23
Am I right in thinking that the problem might be related to SOGo version 5.12.7?
mrmarkuz
(Markus Neuberger)
24
I’m not sure as it worked in some tests without issues.
I also couldn’t reproduce them.
To install the new testing version:
add-module ghcr.io/nethserver/sogo:2.2.1-dev.1
To upgrade to the new testing version: (Be sure to have a backup)
api-cli run update-module --data '{"module_url":"ghcr.io/nethserver/sogo:2.2.1-dev.1","instances":["sogo1"]}'
When you are seeing this, you have propably a reverse proxy to https://dowmain.tld/SOGo/
Try to change this to https://dowmain.tld/
