I have myself my heros.
christian burnat: one week before to die was saying, ‘I wish I could do more SME’
charlie braddy: do something
I’ve seen the years go by, but I still have the energy and enthusiasm to achieve great things with you all!
I recall both from SME days! Great guys!
Good Charlie Brady really had the vision and power to push Mitel, SME, whatever!
You are built of the same clay, and the Gaul spirit:
We can dream it, We can DO IT !!!
I’ve cleared the cache and also tried in incognito, but i don’t see Sogo of Webserver app in the list
You can see they are installed, but not appear in the installed list
Which ns8-sogo app version do you have?
It was installed from software center or from command line?
SOGo is a free and modern scalable groupware server.
Instance sogo1
Version 2.0.0
NGINX web server with php-fpm stack
Instance webserver1
Version 1.0.1
All installed from software center, but not visible any more
I’ve found the problem.
The Threat shield of Nethsecurity is blocking the repo.
When i turn of Threat shield the Sogo and Nginx app are back in the software center
Turning Threat shield on again and both apps are disapeared
Now i need to find out which filter causes the problem
------------------ Update -----------------
Ok. It is the “yoyo IPs” filter which is causing the problem.
blocking some github IPs I guess.
Not the first time…
I was a big fan of SOGo we made and maintain rpms for SME (+ integrations with Thunderbird) but now the project is not the same anymore, so we have chosen a different path.
@lucag is Webtop Product Manager in Nethesis and we trust the project.
A version with new and modern UI is coming… and it’s amazing…
I’m willing to consider a change. Any timelines?
Yeah i use it. I did not want to tell it before you @alefattorini
Let’s hope it works like Sogo ![]()
Currently i’m not able to get Webtop working with the Calender and Contacts
With Sogo no problem, but Webtop does not work with Oulook nor IOS devices
Hi @alefattorini ,
me too very interested in changes and new UI for WebTop, since you have announced in several threads here in the community forum.
But as @LayLow asked before I’d like to know when it will be available, days, weeks, months ?
Because I have to upset a new server in short term, this will influence my decision or to wait and take a look at the new WebTop or to go again with the still not updated SOGo.
Just a few hints would help, if you still cannot publish all details.
it is a matter that the french company release updates, when available, the update will be available for you ![]()
Any teasers
End september I guess…
but shhhh
@lucag I can not find any sources or dev boards (github/trello) of the work that is being done by Sonicle on Webtop. (maybe my bad)
Grazi!
