NethServer Version: 7.9
Module: SOGo 5.8.4
As I mentioned in the topic, my SOGo does not update the number of WOWorkersCount. Seems like it does not read the template (10 default, tried from 5 to 40) and start always with 3 Workers.
This happened (I’m not sure) after a SOGo upgrade from 5.7. Every Time I try to reconfigure the number of Workers, I get an error and the service does not restart. I have to restart it manually, but it start with 3 again.
Even if i change it with config setprop and do a signal-event nehtserver-sogo-update, it keeps ignoring the value, no errors, but service stops.
Strange behaviour: if I change the MemoryLimit, the change is applied. I still have to start the service manually. Only Workers changes are not recognized.
This is the error I get when I use the web dashboard:
[root@posta ~]# echo '{"action":"configuration","status":"enabled","ActiveSync":"enabled","Dav":"enabled","webAccess":"public","AdminUsers":"admin","VirtualHost":"","WOWorkersCount":"9","SOGoInternalSyncInterval":"30","Notifications":"EMail,Appointment","MailAuxiliaryUserAccountsEnabled":"YES"}' | /usr/bin/setsid /usr/bin/sudo /usr/libexec/nethserver/api/nethserver-sogo/update | jq
"steps": 10,
"pid": 12897,
"args": "",
"event": "nethserver-sogo-update"
"step": 1,
"pid": 12897,
"action": "S00initialize-default-databases",
"event": "nethserver-sogo-update",
"state": "running"
"progress": "0.10",
"time": "0.160729",
"exit": 0,
"state": "done",
"step": 1,
"pid": 12897,
"step": 2,
"pid": 12897,
"action": "S05generic_template_expand",
"state": "running"
"progress": "0.20",
"time": "0.104368",
"exit": 256,
"state": "done",
"step": 2,
"pid": 12897,
"step": 3,
"pid": 12897,
"action": "S10nethserver-sogo-mysqlsetup",
"state": "running"
"progress": "0.30",
"time": "0.00876",
"exit": 0,
"state": "done",
"step": 3,
"pid": 12897,
"step": 4,
"pid": 12897,
"action": "S20nethserver-sogo-gnustepsetup",
"state": "running"
"progress": "0.40",
"time": "0.002433",
"exit": 0,
"state": "done",
"step": 4,
"pid": 12897,
"step": 5,
"pid": 12897,
"action": "S30nethserver-sogo-MigrationV3.2.10ToV4.0.0",
"state": "running"
"progress": "0.50",
"time": "0.199446",
"exit": 256,
"state": "done",
"step": 5,
"pid": 12897,
"step": 6,
"pid": 12897,
"action": "S31nethserver-sogo-MigrationV5.3.0ToV5.6.0",
"state": "running"
"progress": "0.60",
"time": "0.018806",
"exit": 256,
"state": "done",
"step": 6,
"pid": 12897,
"step": 7,
"pid": 12897,
"action": "S40nethserver-sogo-create-selfHost",
"state": "running"
"progress": "0.70",
"time": "2.360487",
"exit": 0,
"state": "done",
"step": 7,
"pid": 12897,
"step": 8,
"pid": 12897,
"action": "S50nethserver-sogo-disable-webtop-activesync",
"state": "running"
"progress": "0.80",
"time": "0.057107",
"exit": 0,
"state": "done",
"step": 8,
"pid": 12897,
"step": 9,
"pid": 12897,
"action": "S60nethserver-sogo-remove-slice-messages",
"state": "running"
"progress": "0.90",
"time": "0.003333",
"exit": 0,
"state": "done",
"step": 9,
"pid": 12897,
"step": 10,
"pid": 12897,
"action": "S90adjust-services",
"state": "running"
"progress": "1.00",
"time": "1.299811",
"exit": 0,
"state": "done",
"step": 10,
"pid": 12897,
"pid": 12897,
"status": "failed",
"type": "EventError",
"id": 1694423293,
"message": "update_action_failed"
systemctl status sogod
● sogod.service - SOGo is a groupware server
Loaded: loaded (/usr/lib/systemd/system/sogod.service; disabled; vendor preset: disabled)
Active: active (running) since Mon 2023-09-11 11:22:17 CEST; 3s ago
Process: 20013 ExecStart=/usr/sbin/sogod -WOWorkersCount ${PREFORK} -WOPidFile /var/run/sogo/sogo.pid -WOLogFile /var/log/sogo/sogo.log (code=exited, status=0/SUCCESS)
Main PID: 20014 (sogod)
CGroup: /system.slice/sogod.service
├─20014 /usr/sbin/sogod -WOWorkersCount 3 -WOPidFile /var/run/sogo/sogo.pid -WOLogFile /var/log/sogo/sogo.log
├─20015 /usr/sbin/sogod -WOWorkersCount 3 -WOPidFile /var/run/sogo/sogo.pid -WOLogFile /var/log/sogo/sogo.log
├─20016 /usr/sbin/sogod -WOWorkersCount 3 -WOPidFile /var/run/sogo/sogo.pid -WOLogFile /var/log/sogo/sogo.log
└─20017 /usr/sbin/sogod -WOWorkersCount 3 -WOPidFile /var/run/sogo/sogo.pid -WOLogFile /var/log/sogo/sogo.log
Sep 11 11:22:17 posta.servicesas.it systemd[1]: Starting SOGo is a groupware server...
Sep 11 11:22:17 posta.servicesas.it systemd[1]: Can't open PID file /var/run/sogo/sogo.pid (yet?) after start: No such file or directory
Sep 11 11:22:17 posta.servicesas.it systemd[1]: Started SOGo is a groupware server.
config show sogod
sogod=service
ActiveSync=enabled
AdminUsers=admin
BackupTime=30 0
Certificate=
CustomEmailField=userPrincipalName
Dav=enabled
DraftsFolder=Drafts
MailAuxiliaryUserAccountsEnabled=YES
Notifications=EMail,Appointment
SOGoInternalSyncInterval=30
SOGoMaximumPingInterval=3540
SOGoMaximumSyncInterval=3540
SOGoMaximumSyncResponseSize=2048
SOGoMaximumSyncWindowSize=100
SentFolder=Sent
SessionDuration=1440
SxVMemLimit=1024
TrashFolder=Trash
VirtualHost=
WOWatchDogRequestTimeout=60
WOWorkersCount=9
status=enabled
webAccess=public
after a few minutes I restarted the service, I get WOWatchDog error in the logs and Outlook clients stops receving mail:
Sep 11 11:46:46 sogod [20014]: [ERROR] <0x0x55d79faefea0[WOWatchDog]> No child available to handle incoming request!
Sep 11 11:46:47 sogod [20014]: [ERROR] <0x0x55d79faefea0[WOWatchDog]> No child available to handle incoming request!
Sep 11 11:46:48 sogod [20014]: [WARN] <0x0x55d79fac8f70[WOWatchDogChild]> pid 20016 has been hanging in the same request for 12 minutes
Sep 11 11:46:48 sogod [20014]: [ERROR] <0x0x55d79faefea0[WOWatchDog]> No child available to handle incoming request!
Sep 11 11:46:50 sogod [20014]: [ERROR] <0x0x55d79faefea0[WOWatchDog]> No child available to handle incoming request!
Sep 11 11:46:51 sogod [20014]: [ERROR] <0x0x55d79faefea0[WOWatchDog]> No child available to handle incoming request!
Sep 11 11:46:52 sogod [20014]: [ERROR] <0x0x55d79faefea0[WOWatchDog]> No child available to handle incoming request!
Sep 11 11:46:53 sogod [20015]: <0x0x55d79fa255a0[SOGoActiveSyncDispatcher]> Sleeping 30 seconds while detecting changes for user marco in Ping...
Sep 11 11:46:54 sogod [20014]: [ERROR] <0x0x55d79faefea0[WOWatchDog]> No child available to handle incoming request!
Sep 11 11:46:54 sogod [20016]: <0x0x55d79f846220[SOGoActiveSyncDispatcher]> Sleeping 30 seconds while detecting changes for user carolina in Ping...
Sep 11 11:46:55 sogod [20014]: [ERROR] <0x0x55d79faefea0[WOWatchDog]> No child available to handle incoming request!
Sep 11 11:46:56 sogod [20014]: [ERROR] <0x0x55d79faefea0[WOWatchDog]> No child available to handle incoming request!
Sep 11 11:46:57 sogod [20014]: [WARN] <0x0x55d79fae1ae0[WOWatchDogChild]> pid 20017 has been hanging in the same request for 8 minutes
Sep 11 11:46:57 sogod [20014]: [ERROR] <0x0x55d79faefea0[WOWatchDog]> No child available to handle incoming request!
Sep 11 11:46:59 sogod [20014]: [ERROR] <0x0x55d79faefea0[WOWatchDog]> No child available to handle incoming request!
Any idea why sogo ignores the template?
Simone
