we have a new version of SOGo, I build it, thank to mark who provides a new spec file
Sorry we confuse you: the libwbxml has nothing to do with your problem. It’s a build requirement statical linked in Sogo at build time. It is not installed. going trough the SPEC we use to build Sogo I remembered we should try to build against a newer version.
It’s also hard to reproduce: install sogo 3.2.x use it, remove it and install Sogo 4.2.0
probably a ownership isseu, let me think about that..
does systemctl status sogo give clue’s ?
Who owns /var/log/sogo ? should be sogo:sogo
Who owns /etc/sogo/sogo.conf ? should be root:sogo
# systemctl restart sogod
Job for sogod.service failed because a timeout was exceeded. See "systemctl status sogod.service" and "journalctl -xe" for details.
[root@cloud ~]# systemctl status sogod
● sogod.service - SOGo is a groupware server
Loaded: loaded (/usr/lib/systemd/system/sogod.service; enabled; vendor preset: disabled)
Active: failed (Result: timeout) since Fri 2020-05-22 09:01:34 CEST; 50s ago
Process: 22285 ExecStart=/usr/sbin/sogod -WOWorkersCount ${PREFORK} -WOPidFile /var/run/sogo/sogo.pid -WOLogFile /var/log/sogo/sogo.log (code=killed, signal=TERM)
May 22 09:00:04 cloud.gaillet.be systemd[1]: Starting SOGo is a groupware server...
May 22 09:01:34 cloud.gaillet.be systemd[1]: sogod.service start operation timed out. Terminating.
May 22 09:01:34 cloud.gaillet.be systemd[1]: Failed to start SOGo is a groupware server.
May 22 09:01:34 cloud.gaillet.be systemd[1]: Unit sogod.service entered failed state.
May 22 09:01:34 cloud.gaillet.be systemd[1]: sogod.service failed.
# ls -lai /var/log/sogo
total 60
3411207 drwx------. 2 sogo sogo 4096 Jan 23 17:09 .
3408261 drwxr-xr-x. 25 root root 24576 May 21 07:11 ..
3411206 -rw-r--r--. 1 olefy olefy 0 Jun 9 2019 sogo.log
# ls -lai /etc/sogo/sogo.conf
2622854 -rw-r----- 1 root sogo 4107 May 21 12:05 /etc/sogo/sogo.conf
That may be a good track however. I rm -rf the log/sogo directory and it did not recreate even after a signal-event nethserver-sogo-update.
olefy is wrong, but how come?
try chown -R sogo:sogo /var/log/sogo
you may edit /etc/sogo/sogo.conf and remove the marked-out (//) of some debug settings:
/* 80 Debug */
//SOGoDebugRequests = YES;
//SoDebugBaseURL = YES;
//ImapDebugEnabled = YES;
//LDAPDebugEnabled = YES;
//PGDebugEnabled = YES;
//MySQL4DebugEnabled = YES;
//SOGoUIxDebugEnabled = YES;
//WODontZipResponse = YES;
//SOGoEASDebugEnabled = YES;
NOTE: this is a templated conf file, changes will be lost by a update event
and restart sogod, it should write some stuff to the log
Still nothing in /var/log/sogo, even with debug. That’s really strange. Don’t know how that olefy user came there either.
That olefy thing is really weird.
# tail /etc/passwd
olefy:x:983:978::/home/olefy:/bin/bash
sogo:x:982:977:SOGo daemon:/var/lib/sogo:/sbin/nologin
Those are the two last users created on my system.
Also :
# find / -group olefy
/var/lib/sogo/GNUstep
/var/lib/sogo/GNUstep/Defaults
/var/lib/sogo/GNUstep/Defaults/.lck
/var/lib/sogo/backups
/var/lib/sogo/backups/sogo-2019-05-27_0030
/var/lib/sogo/backups/sogo-2019-05-27_0030/admin
/var/lib/sogo/backups/sogo-2019-05-27_0030/anne-lise
/var/lib/sogo/backups/sogo-2019-05-27_0030/matthieu
/proc/747/map_files/7fa569682000-7fa569686000
/proc/747/map_files/7fa569686000-7fa569688000
/proc/747/map_files/7fa56968d000-7fa56978e000
Update : I did my own version of @stephdl’s bazooka :
find / -name "*sogo*" -exec rm -rf {} +
Then reinstalled. The service starts !! Now there is still a 503 service unavailable problem but I guess that should be solved easily.
So there was probably something wrong with access rights and that olefy user. Thanks @mark_nl and all for brainstorming with me
Glad did you solved, @pagaille. I should anyway advice to backup before trying to do the same thing! Even a nice snapshot could be a great idea.
True @pike. However I’m not sure that in this case it would have helped much since it looks like a mixup with access rights.
Sogo was uninstalled for one year, there have been a lot of changes meanwhile. Moreover, since I use it only as a frontend for the imap server I didn’t really care about any content or configuration.
