SOGO CalDav is not running - but Webtop CalDav
Hello
I have a problem syncing SOGO (Calendar) with CalDAV on our smartphones.
It is when I want to set up the account always synonymous with the following CalDav address to sync:
https://buero.nandlnet.de/webtop-dav/server.php
Since I do not work with Webtop it is thus empty.
I reinstalled the sogo and nethserver-sogo but no change!
This is annoying when something does not work which should work!
Can you help me that the forwarding is running properly again. Thank you!
Do I understand correctly you have webtop and SOGo installed ?
could you post your /etc/conf.d/default-virtualhost.inc?
cat /etc/httpd/conf.d/default-virtualhost.inc
as an quick work around you can try to set your smartphone up to “bypass” the webservers (apache) rewrites. The direct url to SOGo/dav is in your case:
https://buero.nandlnet.de/SOGo/dav
problem solved
The following conf files of Webtop5 were available in /etc/httpd/conf.d/:
webtop5-webdav.conf webtop.conf
I removed them and let the httpd configuration update, then everything ran again.
Annoying such problems!
I had until 2 days ago both for testing installed, now only SOGO is installed.
When uninstalling, they were apparently not removed - that curious that as long as webtop5 was installed, there were no problems.
Happy to read you got everything running again.
Nevertheless, it is a #bug; rewrite rules on the default domain should be placed in default-virtualhost.inc
