SOGO and AD name
sogo
v7
activedirectory
(Thorsten) #1
NethServer Version: 7.5
Module: SoGo
Ok, I am not sure if this a just a missunderstanding on my end.
I installed Nethserver 7.5 and enabled AD. Afterwards I installed email module as well as sogo. Now my Domain users have the email.
user@ad.my.tld instead of user@my.tld.
I removed SoGo and installed Webtop 5 - where this “problem” did not occur.
Maybe i did or expect something wrong: What I want is user@my.tld also I want to use SoGo if possible.
TIA
Thorsten
(Markus Neuberger) #2
You may edit the LDAP field userprincipalname with phpldapadmin (in kamikaze mode).
Another way is to set another IMAP field (mail in this case) for getting the mail address and put the correct mail address there:
config setprop sogod IMAPLoginFieldName mail
signal-event nethserver-sogo-update
Both ways are explained here:
http://docs.nethserver.org/en/v7/sogo.html#esmith-database
