SOGo and AD brainstorming
I don’t understand why. At Outlook caldav synchronizer I had the problem with the certificate, I had to install it at IE, but if you have’nt change anything its “magical” :wink:
To any documentation writer, please feel fre to edit the sogo wiki page and add some admin feedbacks.
I tried to add some contents and I would be pleased if you can enhance it
Fun the ‘mail’ field doesn’t exist in the samba4 Ldap, this field can be found in openldap, can you install nethserver-phpldapadmin and see if your user gets this property
It exists in M$ AD, I can see it using ldapsearch
I need your help, my time is really limited right now
what is the full ldapsearch command
well nothing related to ‘mail’ in samba4 LDAP
ldapsearch -Z -x -D CN=Admin,CN=Users,dc=ad,dc=plop,dc=org -w 'MYSTRONGPASSWORD' -b CN=Users,dc=ad,dc=plop,dc=org -h 192.168.12.46
this is the output
# toto, Users, ad.plop.org
dn: CN=toto,CN=Users,DC=ad,DC=plop,DC=org
objectClass: top
objectClass: person
objectClass: organizationalPerson
objectClass: user
cn: toto
givenName: stephane de labrusse
instanceType: 4
whenCreated: 20171010203700.0Z
displayName: stephane de labrusse
uSNCreated: 3737
objectGUID:: bocLKq0eYUicsr2LdvmrEQ==
badPwdCount: 0
codePage: 0
countryCode: 0
badPasswordTime: 0
lastLogoff: 0
primaryGroupID: 513
objectSid:: AQUAAAAAAAUVAAAA05ZY3HvDMEYE9H7sUQQAAA==
sAMAccountName: toto
sAMAccountType: 805306368
objectCategory: CN=Person,CN=Schema,CN=Configuration,DC=ad,DC=plop,DC=org
loginShell: /usr/libexec/openssh/sftp-server
unixHomeDirectory: /var/lib/nethserver/home/toto
userPrincipalName: toto@nethservertest.org
userAccountControl: 66048
accountExpires: 0
pwdLastSet: 131521414258217010
lastLogonTimestamp: 131521414674563620
whenChanged: 20171010203747.0Z
uSNChanged: 3745
lastLogon: 131521415586992820
logonCount: 28
distinguishedName: CN=toto,CN=Users,DC=ad,DC=plop,DC=org
@davidep, some input on the ‘mail’ property in samba4, I’m puzzled :slight_smile:
mine is a w2008r2 AD DC… no samba4 DC on this side… I have to work only with M$ AD from 2008r2 to 2016
will post tomorrow my ldapsearch result.
In any case, we’d have a key in configuration to tell the system we’re joined to a M$ or a Samba4 AD, so we can use the proper fileds in sogo’s conf…
OK :slight_smile:
yes a key name could be imagined for the IMAPLoginFieldName. First we can decide to do it in the sogo’s side but it will be a manual action. I’m not sure that we can do something automatic here.
I wil be interested
here it is
dn: CN=Stefano Zamboni,CN=Users,DC=dominio,DC=local
objectClass: top
objectClass: person
objectClass: user
cn: Stefano Zamboni
sn: Zamboni
givenName: Stefano
distinguishedName: CN=Stefano Zamboni,CN=Users,DC=dominio,DC=local
instanceType: 4
whenCreated: 20171009100912.0Z
whenChanged: 20171009112635.0Z
displayName: Stefano Zamboni
uSNCreated: 12869
uSNChanged: 12983
objectGUID:: j8zjI5jDAkaicDOqjQwibw==
badPwdCount: 0
codePage: 0
countryCode: 0
badPasswordTime: 0
lastLogoff: 0
lastLogon: 131522113073066265
pwdLastSet: 131520173527968750
primaryGroupID: 513
objectSid:: AQUAAAAAAAUVAAAAJ3qZWx5M3HO4DTVUUwQAAA==
accountExpires: 9223372036854775807
logonCount: 469
sAMAccountName: s.zamboni
userPrincipalName: s.zamboni@dominio.local
objectCategory: CN=Person,CN=Schema,CN=Configuration,DC=dominio,DC=local
dSCorePropagationData: 16010101000000.0Z
lastLogonTimestamp: 131520174140468750
mail: s.zamboni@dominio-cliente.it
mail come from here:
The userPrincipalName field is defined as the “official” user’s email address (and is good for logging in on a workstation too).
With a local AD accounts provider the userPrincipalName value is automatically set in user long name form, i.e. toto@nethserver.org - applying the NethServer domain name.
Instead, the default AD behavior is using the AD domain as suffix (i.e. toto@ad.plop.org). In this case, if you want to set userPrincipalName to a good email address, the configuration must be done manually - or using a Power Shell script or similar.
As alternative you could use the mail field or similar, if you can trust its value. Again, it must be set manually. The field must be also configured to be used by SOGo as well.
ok the best is to release a customisable key by the command line
@Stefano_Zamboni I can see several sogo variables related to userPrincipalName
    IMAPLoginFieldName = userPrincipalName;
    bindFields = (
            sAMAccountName,
            userPrincipalName
    MailFieldNames = ("userPrincipalName");
did you changed all ?
can u test this rpm
yum install http://mirror.de-labrusse.fr/NethDev/nethserver-sogo/nethserver-sogo-1.6.12-1.ns7.sdl.noarch.rpm
config setprop sogod IMAPLoginFieldName mail
signal-event nethserver-sogo-update
then all values ‘userPrincipalName’ will be changed to ‘mail’
for reversing
config setprop sogod IMAPLoginFieldName ''
or
config delprop sogod IMAPLoginFieldName
Fantastic, it seems to work perfectly!
I’m testing in a test environment, but what is the safest method to upgrade a SOGo 3.2.9 installation using nethserver-sogo-1.6.12-1.ns7.sdl.noarch.rpm package?
sogo released with the customisable field IMAPLoginFieldName
The only issue I encounter is sharing user-mailboxes, when the malbox name is not equal to the username.
// Shared mailboxes are { $dovecot{SharedMailboxesStatus} }
namespace SHARED_USERS {
type = shared
disabled = { $dovecot{SharedMailboxesStatus} eq ‘enabled’ ? ‘no’ : ‘yes’ }
separator = /
prefix = Shared/%%n@{{ $DomainName }}/
location = maildir:/var/lib/nethserver/vmail/%%u/Maildir:INDEXPVT=~/Maildir/shared**/%%u**
subscriptions = no
list = children
Aside from that, this works like a charm and is much preferred. How do I ever get dovecot to look in the right folder for shared mailboxes tho ?
#sogo.log
Nov 17 14:19:49 sogod [9673]: [ERROR] <0x0x5589e2e4f460[NGImap4Connection]> could not select URL: imap://t.account%40example.com@localhost/Shared/: {RawResponse = “{ResponseResult = {description = “Mailbox doesn’t exist: Shared”; result = no; tagId = 6; }; }”; reason = “Mailbox doesn’t exist: Shared”; result = 0; } Nov 17 14:19:49 sogod [9673]: 192.168.50.38 “POST /SOGo/so/lmst01/Mail/0/folderShared/view HTTP/1.1” 500 72/48 0.340 - - 0
This will not ever match afaik … can I implement email like I am trying atm or is this fruitless and a massive waste of time ?
