Just to let you know, we could not build anymore SOGo on our own, something has changed and the C compilation got complains.
We need to inverstigate
I’m going to try to build SOGo 5.2.0 on Arch Linux this weekend and see how that goes,
hoping to figure out why we have this linker error and how to solve it on EL7.
you are our only hope
yes same compilation error in archlinux : see https://aur.archlinux.org/packages/sogo/
Do you have the phone number of deons ?
checked the sogo.git of arch, will try it :-?
Over here SOGo 5.2.0 builds fine on Arch Linux
Have not figured out why…
I move slowly sorry, next step is a new compilation error
SOGoTNEFMailBodyPart.m:43:18: fatal error: ytnef.h: No such file or directory
#import <ytnef.h>
compilation terminated.
gmake[3]: *** [obj/Mailer.obj/SOGoTNEFMailBodyPart.m.o] Error 1
gmake[2]: *** [Mailer.all.wobundle.variables] Error 2
gmake[2]: Leaving directory `/builddir/build/BUILD/sogo-SOGo-5.2.0/SoObjects/Mailer'
gmake[1]: *** [internal-all] Error 2
gmake[1]: Leaving directory `/builddir/build/BUILD/sogo-SOGo-5.2.0/SoObjects'
make: *** [internal-all] Error 2
error: Bad exit status from /var/tmp/rpm-tmp.jI3sss (%build)
Add ytnef libytnef libytnef-devel to the BuildRequires, I guess we have to build a our version of ytnef
I think we need to build
ytnef
libytnef
libytnef-devel
SOGo now use ytnef == 1.9.3 and epel use another version 2.6-12
If I do a BuildRequire ...... ytnef = 1.9.3 , libytnef libytnef-devel and I push the ytnef version of SOGo to the local repository, then the error is changed
Transaction check error:
file /usr/lib64/libytnef.so.0.0.0 conflicts between attempted installs of ytnef-1.9.3-1.x86_64 and libytnef-1.5-14.el7.x86_64
It did not come to my mind the version off ytnef could be a problem…
And still do not see the how it relates to the problem the linker can not find the compiled Sogo objects
( /usr/bin/ld: cannot find -lSOGo )
Going to dive in the over the weekend again.
ytnef is needed in the Requires of the sogo rpm now
libytnef-devel is needed in the Buildrequires of sogo for the missing linker
Unfortunately EPEL provide a rpm of the epoch 0 (2.6) and we need a version of the epoch 1 (1.9.3)
Now I have another error that an import is missing even if I build myself the rpm of *ytnef*, probably the file is not in the good path because I took a spec of fedora
#import <ytnef.h>
to be continued
the goal of SOGo developers
%description
Yerase's TNEF Stream Reader. Can take a TNEF Stream (winmail.dat) sent from
Microsoft Outlook (or similar products) and extract the attachments, including
construction of Contact Cards & Calendar entries.
cd /path/2/yourfolder
wget https://packages.inverse.ca/SOGo/nightly/5/rhel/7/x86_64/RPMS/ytnef-1.9.3-1.x86_64.rpm
createrepo /path/2/yourfolder
add
Requires ..... ytnef = 1.9.3
BuildRequires ..... ytnef = 1.9.3
That’s it we can build SOGo but we need to push in nethforge ytnef as a requirement
-rw-r--r-- 1 stephdl stephdl 359K 17 sept. 16:15 libwbxml-0.11.6-1.ns7.src.rpm
-rw-r--r-- 1 stephdl stephdl 96K 17 sept. 16:15 libwbxml-0.11.6-1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 200K 17 sept. 16:15 libwbxml-debuginfo-0.11.6-1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 14K 17 sept. 16:15 libwbxml-devel-0.11.6-1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 33M 17 sept. 16:20 sogo-5.2.0-1.ns7.src.rpm
-rw-r--r-- 1 stephdl stephdl 20M 17 sept. 16:20 sogo-5.2.0-1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 142K 17 sept. 16:20 sogo-activesync-5.2.0-1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 1,8M 17 sept. 16:20 sogo-debuginfo-5.2.0-1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 376K 17 sept. 16:20 sogo-devel-5.2.0-1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 16K 17 sept. 16:20 sogo-ealarms-notify-5.2.0-1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 16K 17 sept. 16:20 sogo-slapd-sockd-5.2.0-1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 59K 17 sept. 16:20 sogo-tool-5.2.0-1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 2,2M 17 sept. 16:18 sope49-4.9-5.2.0.1.ns7.src.rpm
-rw-r--r-- 1 stephdl stephdl 923K 17 sept. 16:18 sope49-appserver-4.9-5.2.0.1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 215K 17 sept. 16:18 sope49-appserver-devel-4.9-5.2.0.1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 208K 17 sept. 16:20 sope49-cards-5.2.0-1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 117K 17 sept. 16:20 sope49-cards-devel-5.2.0-1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 348K 17 sept. 16:18 sope49-core-4.9-5.2.0.1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 63K 17 sept. 16:18 sope49-core-devel-4.9-5.2.0.1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 2,8M 17 sept. 16:18 sope49-debuginfo-4.9-5.2.0.1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 173K 17 sept. 16:18 sope49-gdl1-4.9-5.2.0.1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 68K 17 sept. 16:20 sope49-gdl1-contentstore-5.2.0-1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 73K 17 sept. 16:20 sope49-gdl1-contentstore-devel-5.2.0-1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 27K 17 sept. 16:18 sope49-gdl1-devel-4.9-5.2.0.1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 37K 17 sept. 16:18 sope49-gdl1-mysql-4.9-5.2.0.1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 43K 17 sept. 16:18 sope49-gdl1-postgresql-4.9-5.2.0.1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 54K 17 sept. 16:18 sope49-ldap-4.9-5.2.0.1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 11K 17 sept. 16:18 sope49-ldap-devel-4.9-5.2.0.1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 305K 17 sept. 16:18 sope49-mime-4.9-5.2.0.1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 33K 17 sept. 16:18 sope49-mime-devel-4.9-5.2.0.1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 20K 17 sept. 16:18 sope49-sbjson-2.3.1-5.2.0.1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 11K 17 sept. 16:18 sope49-sbjson-devel-2.3.1-5.2.0.1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 208K 17 sept. 16:18 sope49-xml-4.9-5.2.0.1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 28K 17 sept. 16:18 sope49-xml-devel-4.9-5.2.0.1.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 303K 17 sept. 16:18 ytnef-1.9.3-3.ns7.src.rpm
-rw-r--r-- 1 stephdl stephdl 65K 17 sept. 16:18 ytnef-1.9.3-3.ns7.x86_64.rpm
-rw-r--r-- 1 stephdl stephdl 83K 17 sept. 16:18 ytnef-debuginfo-1.9.3-3.ns7.x86_64.rpm
Need to test now
