SOGo 5.12.1 needs testers
Hello mates
SOGo 5.12.1 is available for tests
  • first install
    add-module ghcr.io/nethserver/sogo:2.0.8-dev.1
  • upgrade
    api-cli run update-module --data '{"module_url":"ghcr.io/nethserver/sogo:2.0.8-dev.1","instances":["sogo1"],"force":true}'
the changelog is at : sogo/CHANGELOG.md at master · Alinto/sogo · GitHub
the issue to verify is : Upgrade SOGo to 5.12.1 · Issue #7468 · NethServer/dev · GitHub
Hi @stephdl
There is nothing left to say. Except that the update works without any problems and there are no anomalies.
Regards…
Uwe
Stéphane. That incredibly fast !!
Tested it on my test server and installed correctly (as ever)
Great Job !!
@stephdl Thanks again, u r a speedy and everything work correct.
released
