stephdl
(Stéphane de Labrusse)
1
Hello mates
SOGo 5.12.0 is available for tests
first install
add-module ghcr.io/nethserver/sogo:sdl-7416
upgrade
api-cli run update-module --data '{"module_url":"ghcr.io/nethserver/sogo:sdl-7416","instances":["sogo1"],"force":true}'
the changelog is at : sogo/CHANGELOG.md at master · Alinto/sogo · GitHub
the issue to verify is : feat(sogo): Upgrade from 5.11.2 to 5.12.0 · Issue #7416 · NethServer/dev · GitHub
Hi @stephdl
Done and it works. So far without any problems.
Installation went smoothly
Hi @stephdl
I hope that your health is still on the right track.
When can we expect the final release?
Regards…
Uwe
stephdl
5
You should have this version ?
mrmarkuz
(Markus Neuberger)
7
You could update from testing to the current version by using api-cli:
api-cli run update-module --data '{"module_url":"ghcr.io/nethserver/sogo:2.0.7","instances":["sogo1"],"force":true}'
There is new update 5.12.1
- Mainly bugfixes.
- The property URL of an event is now implemented. Before that, some links may be missing if the event was made by other calendar applications.
- Event invitation sent from SOGo are now supported by outlook.office.com
- Webmail is now usable again with Iphone/Ipad.
The invation is a important bug fix for me.
Something this goes wrong now
