to upgrade
yum update sogo\* sope\* --enablerepo=nethforge-testing
to install
yum install nethserver-sogo --enablerepo=nethforge-testing
probably the last version on NS7
to upgrade
to install
I could not recommend to use sogo 5.10.0 because of there is a strange bug with calendar !
The bug is caused by recurring dates. So when you have some birthdays or other recurring events then the web ui is crashing.
Mail and Contact part of web ui is not affected and working well.
best regards Denis
thanks, maybe it is safer to wait 5.10.1
her some good news: the calendar bug was fixed 2 days ago.
@Stéphane You should recompile sogo from actual source code or you should install it from daily rpm…
Now it makes sense to test it ![]()
nothing released
Is it possible to currently install version 5.9.1 while waiting for 5.10.1? The bug of not deleting events in the shared calendar on Thunderbird is really annoying…
