NethServer Version: 6.10
Module: SOGo
Hello, anyone knows if is it possible to install SOGo 4 (or update from SOGo 3, available on Software Center) on NethServer 6?
Thanks.
Module: SOGo
Thanks.
I imagine yes but you need to install sogo4 from the sogo nightly build repository.
I would prefer to encourage you to upgrade to ns7… Eol for ns6 is 2020 iirc
I agree with @stephdl.
Also, bear in mind that NS 6 is in maintenance phase: no new features will be added, the system will receive only bug an security fixes.
