stephdl
(Stéphane de Labrusse)
May 22, 2020, 3:42pm
1
With the great help of @mark_nl , we have released a new version of sogo, you should testing it please. The upgrade is smooth, the service is up and workable only nethserver 7.8
yum update --enablerepo=nethforge-testing
yum install nethserver-sogo --enablerepo=nethforge-testing
the changelog: https://github.com/inverse-inc/sogo/releases/tag/SOGo-4.3.2
Please have a go
mark_nl
(Mark Verlinde)
May 22, 2020, 4:11pm
2
Please also test ActiveSync
We build Sogo with an updated library: libwbxml-0.11.6.
It promises better support for the newer ActiveSync protocoll v16.0.
Happy testing
stephdl
May 23, 2020, 6:17pm
3
my own server is updated, no errors so far
hucky
(kai)
May 24, 2020, 1:25pm
4
i also updated and also no errors so far, thanks guys !!!
mrmarkuz
(Markus Neuberger)
May 24, 2020, 6:59pm
5
Updated a server without errors. Tested EAS with Android mobile and it works so far.
Great work guys!
royceb
(Royce)
May 24, 2020, 11:55pm
6
Updated and tested, works here both on web client and EAS on android sending & receiving.
mark_nl
(Mark Verlinde)
May 25, 2020, 1:38pm
7
Did two updates and a new install in a test environment and found no issues nor regression myself.
one update in a NS VM and one fresh installation in another NS VM.
Everything looks good.
Regards…
Uwe
mark_nl
(Mark Verlinde)
June 2, 2020, 7:10pm
9
@pagaille did you try to update?
Quite frankly i’m most worried about your setup excluding some packages form epel repositories …
Other wise i’ll think we ready to release the update
pagaille
(Matthieu Gaillet)
June 2, 2020, 7:33pm
10
I missed that. But since excluding epel installs the versions expected by sogo I suppose it should work .
Will try tonight.
pagaille
(Matthieu Gaillet)
June 3, 2020, 9:12am
11
Updated, everything is working. I didn’t test extensively but basic functionalities are ok. Thanks !!
# yum update --enablerepo=nethforge-testing
Loaded plugins: changelog, fastestmirror, nethserver_events, remove-with-leaves
* ce-base: mirror.bytemark.co.uk
* ce-extras: mirror.bytemark.co.uk
* ce-sclo-rh: mirror.bytemark.co.uk
* ce-sclo-sclo: mirror.bytemark.co.uk
* ce-updates: mirror.bytemark.co.uk
* epel: mirror.imt-systems.com
* nethforge: mirror.alpix.eu
* nethserver-base: mirror.alpix.eu
* nethserver-updates: mirror.alpix.eu
nethforge-testing/7/x86_64/signature | 836 B 00:00:00
nethforge-testing/7/x86_64/signature | 2.9 kB 00:00:00 !!!
nethforge-testing/7/x86_64/primary_db | 26 kB 00:00:00
Resolving Dependencies
--> Running transaction check
---> Package sogo.x86_64 0:4.3.0-1.ns7 will be updated
---> Package sogo.x86_64 0:4.3.2-1.ns7 will be an update
---> Package sogo-activesync.x86_64 0:4.3.0-1.ns7 will be updated
---> Package sogo-activesync.x86_64 0:4.3.2-1.ns7 will be an update
---> Package sogo-ealarms-notify.x86_64 0:4.3.0-1.ns7 will be updated
---> Package sogo-ealarms-notify.x86_64 0:4.3.2-1.ns7 will be an update
---> Package sogo-tool.x86_64 0:4.3.0-1.ns7 will be updated
---> Package sogo-tool.x86_64 0:4.3.2-1.ns7 will be an update
---> Package sope49-appserver.x86_64 0:4.9-20191218_1900.ns7 will be updated
---> Package sope49-appserver.x86_64 1:4.9-4.3.2.1.ns7 will be an update
---> Package sope49-cards.x86_64 0:4.3.0-1.ns7 will be updated
---> Package sope49-cards.x86_64 0:4.3.2-1.ns7 will be an update
---> Package sope49-core.x86_64 0:4.9-20191218_1900.ns7 will be updated
---> Package sope49-core.x86_64 1:4.9-4.3.2.1.ns7 will be an update
---> Package sope49-gdl1.x86_64 0:4.9-20191218_1900.ns7 will be updated
---> Package sope49-gdl1.x86_64 1:4.9-4.3.2.1.ns7 will be an update
---> Package sope49-gdl1-contentstore.x86_64 0:4.3.0-1.ns7 will be updated
---> Package sope49-gdl1-contentstore.x86_64 0:4.3.2-1.ns7 will be an update
---> Package sope49-gdl1-mysql.x86_64 0:4.9-20191218_1900.ns7 will be updated
---> Package sope49-gdl1-mysql.x86_64 1:4.9-4.3.2.1.ns7 will be an update
---> Package sope49-ldap.x86_64 0:4.9-20191218_1900.ns7 will be updated
---> Package sope49-ldap.x86_64 1:4.9-4.3.2.1.ns7 will be an update
---> Package sope49-mime.x86_64 0:4.9-20191218_1900.ns7 will be updated
---> Package sope49-mime.x86_64 1:4.9-4.3.2.1.ns7 will be an update
---> Package sope49-sbjson.x86_64 0:2.3.1-20191218_1900.ns7 will be updated
---> Package sope49-sbjson.x86_64 1:2.3.1-4.3.2.1.ns7 will be an update
---> Package sope49-xml.x86_64 0:4.9-20191218_1900.ns7 will be updated
---> Package sope49-xml.x86_64 1:4.9-4.3.2.1.ns7 will be an update
Dependencies Resolved
Package Arch Version Repository Size
Updating:
sogo x86_64 4.3.2-1.ns7 nethforge-testing 20 M
sogo-activesync x86_64 4.3.2-1.ns7 nethforge-testing 141 k
sogo-ealarms-notify x86_64 4.3.2-1.ns7 nethforge-testing 16 k
sogo-tool x86_64 4.3.2-1.ns7 nethforge-testing 58 k
sope49-appserver x86_64 1:4.9-4.3.2.1.ns7 nethforge-testing 922 k
sope49-cards x86_64 4.3.2-1.ns7 nethforge-testing 207 k
sope49-core x86_64 1:4.9-4.3.2.1.ns7 nethforge-testing 346 k
sope49-gdl1 x86_64 1:4.9-4.3.2.1.ns7 nethforge-testing 173 k
sope49-gdl1-contentstore x86_64 4.3.2-1.ns7 nethforge-testing 68 k
sope49-gdl1-mysql x86_64 1:4.9-4.3.2.1.ns7 nethforge-testing 37 k
sope49-ldap x86_64 1:4.9-4.3.2.1.ns7 nethforge-testing 54 k
sope49-mime x86_64 1:4.9-4.3.2.1.ns7 nethforge-testing 302 k
sope49-sbjson x86_64 1:2.3.1-4.3.2.1.ns7 nethforge-testing 20 k
sope49-xml x86_64 1:4.9-4.3.2.1.ns7 nethforge-testing 208 k
Transaction Summary
Upgrade 14 Packages
Total download size: 22 M
Is this ok [y/d/N]: y
Downloading packages:
No Presto metadata available for nethforge-testing
(1/14): sogo-activesync-4.3.2-1.ns7.x86_64.rpm | 141 kB 00:00:00
(2/14): sogo-ealarms-notify-4.3.2-1.ns7.x86_64.rpm | 16 kB 00:00:00
(3/14): sogo-tool-4.3.2-1.ns7.x86_64.rpm | 58 kB 00:00:00
(4/14): sope49-appserver-4.9-4.3.2.1.ns7.x86_64.rpm | 922 kB 00:00:00
(5/14): sope49-cards-4.3.2-1.ns7.x86_64.rpm | 207 kB 00:00:00
(6/14): sope49-core-4.9-4.3.2.1.ns7.x86_64.rpm | 346 kB 00:00:00
(7/14): sope49-gdl1-4.9-4.3.2.1.ns7.x86_64.rpm | 173 kB 00:00:00
(8/14): sope49-gdl1-contentstore-4.3.2-1.ns7.x86_64.rpm | 68 kB 00:00:00
(9/14): sope49-gdl1-mysql-4.9-4.3.2.1.ns7.x86_64.rpm | 37 kB 00:00:00
(10/14): sope49-ldap-4.9-4.3.2.1.ns7.x86_64.rpm | 54 kB 00:00:00
(11/14): sope49-mime-4.9-4.3.2.1.ns7.x86_64.rpm | 302 kB 00:00:00
(12/14): sope49-sbjson-2.3.1-4.3.2.1.ns7.x86_64.rpm | 20 kB 00:00:00
(13/14): sogo-4.3.2-1.ns7.x86_64.rpm | 20 MB 00:00:02
(14/14): sope49-xml-4.9-4.3.2.1.ns7.x86_64.rpm | 208 kB 00:00:00
Total 9.5 MB/s | 22 MB 00:00:02
Running transaction test
Transaction test succeeded
Running transaction
Updating : 1:sope49-xml-4.9-4.3.2.1.ns7.x86_64 1/28
Updating : 1:sope49-core-4.9-4.3.2.1.ns7.x86_64 2/28
Updating : 1:sope49-gdl1-4.9-4.3.2.1.ns7.x86_64 3/28
Updating : sope49-gdl1-contentstore-4.3.2-1.ns7.x86_64 4/28
Updating : 1:sope49-ldap-4.9-4.3.2.1.ns7.x86_64 5/28
Updating : 1:sope49-mime-4.9-4.3.2.1.ns7.x86_64 6/28
Updating : 1:sope49-appserver-4.9-4.3.2.1.ns7.x86_64 7/28
Updating : 1:sope49-sbjson-2.3.1-4.3.2.1.ns7.x86_64 8/28
Updating : sope49-cards-4.3.2-1.ns7.x86_64 9/28
Updating : sogo-4.3.2-1.ns7.x86_64 10/28
Updating : sogo-activesync-4.3.2-1.ns7.x86_64 11/28
Updating : sogo-tool-4.3.2-1.ns7.x86_64 12/28
Updating : 1:sope49-gdl1-mysql-4.9-4.3.2.1.ns7.x86_64 13/28
Updating : sogo-ealarms-notify-4.3.2-1.ns7.x86_64 14/28
Cleanup : sogo-tool-4.3.0-1.ns7.x86_64 15/28
Cleanup : sogo-activesync-4.3.0-1.ns7.x86_64 16/28
Cleanup : sogo-4.3.0-1.ns7.x86_64 17/28
Cleanup : sope49-appserver-4.9-20191218_1900.ns7.x86_64 18/28
Cleanup : sope49-mime-4.9-20191218_1900.ns7.x86_64 19/28
Cleanup : sope49-ldap-4.9-20191218_1900.ns7.x86_64 20/28
Cleanup : sope49-gdl1-contentstore-4.3.0-1.ns7.x86_64 21/28
Cleanup : sope49-gdl1-mysql-4.9-20191218_1900.ns7.x86_64 22/28
Cleanup : sope49-gdl1-4.9-20191218_1900.ns7.x86_64 23/28
Cleanup : sope49-core-4.9-20191218_1900.ns7.x86_64 24/28
Cleanup : sope49-xml-4.9-20191218_1900.ns7.x86_64 25/28
Cleanup : sope49-cards-4.3.0-1.ns7.x86_64 26/28
Cleanup : sogo-ealarms-notify-4.3.0-1.ns7.x86_64 27/28
Cleanup : sope49-sbjson-2.3.1-20191218_1900.ns7.x86_64 28/28
Verifying : 1:sope49-core-4.9-4.3.2.1.ns7.x86_64 1/28
Verifying : 1:sope49-ldap-4.9-4.3.2.1.ns7.x86_64 2/28
Verifying : 1:sope49-gdl1-mysql-4.9-4.3.2.1.ns7.x86_64 3/28
Verifying : sope49-cards-4.3.2-1.ns7.x86_64 4/28
Verifying : 1:sope49-sbjson-2.3.1-4.3.2.1.ns7.x86_64 5/28
Verifying : sogo-activesync-4.3.2-1.ns7.x86_64 6/28
Verifying : 1:sope49-gdl1-4.9-4.3.2.1.ns7.x86_64 7/28
Verifying : sogo-ealarms-notify-4.3.2-1.ns7.x86_64 8/28
Verifying : sogo-4.3.2-1.ns7.x86_64 9/28
Verifying : sogo-tool-4.3.2-1.ns7.x86_64 10/28
Verifying : 1:sope49-mime-4.9-4.3.2.1.ns7.x86_64 11/28
Verifying : 1:sope49-appserver-4.9-4.3.2.1.ns7.x86_64 12/28
Verifying : 1:sope49-xml-4.9-4.3.2.1.ns7.x86_64 13/28
Verifying : sope49-gdl1-contentstore-4.3.2-1.ns7.x86_64 14/28
Verifying : sogo-tool-4.3.0-1.ns7.x86_64 15/28
Verifying : sope49-cards-4.3.0-1.ns7.x86_64 16/28
Verifying : sope49-gdl1-contentstore-4.3.0-1.ns7.x86_64 17/28
Verifying : sope49-ldap-4.9-20191218_1900.ns7.x86_64 18/28
Verifying : sope49-sbjson-2.3.1-20191218_1900.ns7.x86_64 19/28
Verifying : sogo-activesync-4.3.0-1.ns7.x86_64 20/28
Verifying : sope49-gdl1-mysql-4.9-20191218_1900.ns7.x86_64 21/28
Verifying : sope49-mime-4.9-20191218_1900.ns7.x86_64 22/28
Verifying : sope49-gdl1-4.9-20191218_1900.ns7.x86_64 23/28
Verifying : sogo-ealarms-notify-4.3.0-1.ns7.x86_64 24/28
Verifying : sope49-appserver-4.9-20191218_1900.ns7.x86_64 25/28
Verifying : sogo-4.3.0-1.ns7.x86_64 26/28
Verifying : sope49-core-4.9-20191218_1900.ns7.x86_64 27/28
Verifying : sope49-xml-4.9-20191218_1900.ns7.x86_64 28/28
Updated:
sogo.x86_64 0:4.3.2-1.ns7 sogo-activesync.x86_64 0:4.3.2-1.ns7 sogo-ealarms-notify.x86_64 0:4.3.2-1.ns7 sogo-tool.x86_64 0:4.3.2-1.ns7
sope49-appserver.x86_64 1:4.9-4.3.2.1.ns7 sope49-cards.x86_64 0:4.3.2-1.ns7 sope49-core.x86_64 1:4.9-4.3.2.1.ns7 sope49-gdl1.x86_64 1:4.9-4.3.2.1.ns7
sope49-gdl1-contentstore.x86_64 0:4.3.2-1.ns7 sope49-gdl1-mysql.x86_64 1:4.9-4.3.2.1.ns7 sope49-ldap.x86_64 1:4.9-4.3.2.1.ns7 sope49-mime.x86_64 1:4.9-4.3.2.1.ns7
sope49-sbjson.x86_64 1:2.3.1-4.3.2.1.ns7 sope49-xml.x86_64 1:4.9-4.3.2.1.ns7
Complete!
