Snort: Incorrect Initial Configuration Leading to Failure
When IPS (Snort) is enabled for the first time in the Web UI, if the number of CPU cores (including Hyper-Threading/HT) exceeds 16 (a common occurrence on modern CPUs), the resulting configuration is incorrect, which prevents Snort from functioning.
The core problem is an incorrectly configured number of queues.
For example, a machine with 16 physical cores and HT enabled presents 32 logical processors (threads) to the operating system.
The generated configuration file (/etc/config/snort) contains the following error:
config nfq 'nfq'
        option queue_count '32'
        option thread_count '32'
This configuration triggers the following error upon manual startup service snort restart and check snort-mgr check:
ERROR: In option queue_count=‘32’, must be 1 <= x <= 16 Errors during generation of snort config
But the IPS/Snort is silently broken and the Web UI indicates, that everything is fine,
Solution: Manually edit the number of queues (e.g., set queue_count to 16) and restart the Snort service.
This is the first time we got this reported. The changes you’ve made are being overridden every time the snort config is being saved!
A bug report should be filled, to keep track of it, since you’ve got the gist of it would you kindly do it?
Maybe relevant: config: set queue count limit to 16 (#34) · NethServer/nethserver-suricata@afdb6e5 · GitHub
Filed a bug report:
