SNAT -Masquerade on tun openvpn client tunnel
NethServer Version: 7.9.2009
Module: 3.10.0-1160.76.1.el7.x86_64
Dear Nethserver Community.
I just have successfully configured a tunnel openvpn client on nethserver.
To be able to make everything work,I have to configure a snat on the tunnel interface.
To by pass the problem I have handwritten the rule in the file file SNAT using the command Masquerade,(I find this solution googling),everythings works well but everytime I reboot the service shorewall or I make some updates to configuration ,the rules disappear from file and I have to write again.
Can you help me?
Thanks in advance
Hi and welcome to NethServer Community,
templates are used to write the config files so you need a custom template to make the changes permanent.
Just write the rule to a custom template fragment file /etc/e-smith/templates-custom/etc/shorewall/snat/90customsnat and apply the shorewall configuration:
signal-event firewall-adjust
Now you should see the rule at the end of the /etc/shorewall/snat file.
Thank you !!!
Fantastic!!
You are Great!!
