SMTP Proxy does not work
the bug reported in March is still there. On a fresh installation the smtp proxy package behaves like a mail server and does not allow forwarding mails to the primary mail domain to a local mail server. Please check.
Cheers, Ralph
Are you referring to this bug? SMTP proxy cannot relay primary mail domain
Correct.
It was my fault. I had installed the smtp-proxy plus the eMail package by mistake. After uninstalling both and installing the smtp-proxy anew it works.
OK. Thanks for letting us know the solution.
