> Feb 21 08:33:29 nethserver postfix/smtpd[32222]: connect from uk1-rack-lon2.inumbo.com[162.13.166.7]
> Feb 21 08:33:29 nethserver rspamd[2703]: <82ecc9>; proxy; proxy_accept_socket: accepted milter connection from /var/run/rspamd/worker-proxy port 0
> Feb 21 08:33:29 nethserver postfix/smtpd[32222]: D3CF9E3896: client=uk1-rack-lon2.inumbo.com[162.13.166.7]
> Feb 21 08:33:29 nethserver rspamd[2703]: <82ecc9>; milter; rspamd_milter_process_command: got connection from 162.13.166.7:32388
> Feb 21 08:33:29 nethserver postfix/cleanup[1521]: D3CF9E3896: message-id=<44B8.10KZ3.6B1D87FB5800B8326E9VZF5489698ABCD2C709.20210221083327606@r1.dotdigital-email.com>
> Feb 21 08:33:29 nethserver rspamd[2703]: <82ecc9>; proxy; rspamd_message_parse: loaded message; id: <44B8.10KZ3.6B1D87FB5800B8326E9VZF5489698ABCD2C709.20210221083327606@r1.dotdigital-email.com>; queue-id: <D3CF9E3896>; size: 68376; checksum: <39093f49f91060031f1b2929b79e6029>
> Feb 21 08:33:29 nethserver rspamd[2703]: <82ecc9>; proxy; rspamd_mime_part_detect_language: detected part language: en
> Feb 21 08:33:30 nethserver rspamd[2703]: <82ecc9>; proxy; dkim_module_key_handler: stored DKIM key for dkim1024._domainkey.dkim.dotmailer.com in LRU cache for 3600 seconds, 465/2000 elements in the cache
> Feb 21 08:33:30 nethserver rspamd[2703]: <82ecc9>; proxy; dkim_module_key_handler: stored DKIM key for dkim1024._domainkey.dotdigital-email.com in LRU cache for 3600 seconds, 466/2000 elements in the cache
> Feb 21 08:33:30 nethserver rspamd[2703]: <82ecc9>; proxy; rspamd_redis_connected: skip obtaining bayes tokens for BAYES_SPAM of classifier bayes: not enough learns 119; 200 required
> Feb 21 08:33:30 nethserver rspamd[2703]: <82ecc9>; proxy; rspamd_stat_classifiers_process: skip statistics as SPAM class is missing
> Feb 21 08:33:30 nethserver rspamd[2703]: <82ecc9>; lua; greylist.lua:416: greylisted until "Sun, 21 Feb 2021 08:38:30 GMT", new record
> Feb 21 08:33:30 nethserver rspamd[2703]: <82ecc9>; proxy; rspamd_add_passthrough_result: <44B8.10KZ3.6B1D87FB5800B8326E9VZF5489698ABCD2C709.20210221083327606@r1.dotdigital-email.com>: set pre-result to 'soft reject' (no score): 'Try again later' from greylist(1)
> Feb 21 08:33:30 nethserver rspamd[2703]: <82ecc9>; proxy; rspamd_task_write_log: id: <44B8.10KZ3.6B1D87FB5800B8326E9VZF5489698ABCD2C709.20210221083327606@r1.dotdigital-email.com>, qid: <D3CF9E3896>, ip: 162.13.166.7, from: <SRS0=RAXR=HX=r1.dotdigital-email.com=bo-44b8-10kz3-6e9vzf-c16df@srs-uk1.protection.inumbo.net>, (default: F (soft reject): [6.29/20.00] [RSPAMD_URIBL(4.50){ddlnk.net:url;},MANY_INVISIBLE_PARTS(1.00){10;},HTML_SHORT_LINK_IMG_3(0.50){},FORGED_SENDER(0.30){Stauer@r1.dotdigital-email.com;SRS0=RAXR=HX=r1.dotdigital-email.com=bo-44b8-10kz3-6e9vzf-c16df@srs-uk1.protection.inumbo.net;},BAD_REP_POLICIES(0.10){},MIME_GOOD(-0.10){multipart/alternative;text/plain;},HAS_LIST_UNSUB(-0.01){},MX_GOOD(-0.01){},XM_UA_NO_VERSION(0.01){},ASN(0.00){asn:15395, ipnet:162.13.0.0/16, country:GB;},DKIM_TRACE(0.00){dotdigital-email.com:+;dkim.dotmailer.com:+;},DMARC_POLICY_ALLOW(0.00){r1.dotdigital-email.com;none;},FROM_HAS_DN(0.00){},FROM_NEQ_ENVFROM(0.00){Stauer@r1.dotdigital-email.com;SRS0=RAXR=HX=r1.dotdigital-email.com=bo-44b8-10kz3-6e9vzf-c16df@srs-uk1.protection.inumbo.net;},GENERIC_REPUTATION(0.00){-0.32106786437009;},GREYLIST(0.00){greylisted;Sun, 21 Feb 2021 08:38:30 GMT;new record;},HAS_REPLYTO(0.00){re-44B8-10KZ3-6E9VZF-C16DF@r1.dotdigital-email.com;},IP_REPUTATION_HAM(0.00){asn: 15395(-0.13), country: GB(-0.00), ip: 162.13.166.7(-0.32);},MID_RHS_MATCH_FROM(0.00){},MIME_TRACE(0.00){0:+;1:+;2:~;},RCPT_COUNT_ONE(0.00){1;},RCVD_COUNT_TWO(0.00){2;},RCVD_TLS_ALL(0.00){},REPLYTO_DN_EQ_FROM_DN(0.00){},REPLYTO_DOM_EQ_FROM_DOM(0.00){},R_DKIM_ALLOW(0.00){dotdigital-email.com:s=dkim1024;dkim.dotmailer.com:s=dkim1024;},R_SPF_NA(0.00){no SPF record;},TO_DN_NONE(0.00){},TO_MATCH_ENVRCPT_ALL(0.00){}]), len: 68376, time: 372.450ms, dns req: 60, digest: <39093f49f91060031f1b2929b79e6029>, rcpts: <ADDRESSREDACTED>, mime_rcpts: <ADDRESSREDACTED>, forced: soft reject "Try again later"; score=nan (set by greylist)
> Feb 21 08:33:30 nethserver rspamd[2703]: <82ecc9>; proxy; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 3 regexps matched, 184 regexps total, 80 regexps cached, 0B scanned using pcre, 71.12KiB scanned total
> Feb 21 08:33:30 nethserver postfix/cleanup[1521]: D3CF9E3896: milter-reject: END-OF-MESSAGE from uk1-rack-lon2.inumbo.com[162.13.166.7]: 4.7.1 Try again later; from=<SRS0=RAXR=HX=r1.dotdigital-email.com=bo-44b8-10kz3-6e9vzf-c16df@srs-uk1.protection.inumbo.net> to=<ADDRESSREDACTED> proto=ESMTP helo=<uk1-rack-lon2.inumbo.com>
> Feb 21 08:33:30 nethserver postfix/smtpd[32222]: disconnect from uk1-rack-lon2.inumbo.com[162.13.166.7]
> Feb 21 08:33:30 nethserver rspamd[2703]: <2ded99>; proxy; proxy_milter_finish_handler: finished milter connection
