SMB locked file issue
I’ve an issue with samba. When users made some changes at files, save and close it, nobody can’t modify it again. They get a message that the file is open from the user and it’s in readonly mode. (Also for the same user)
That’s an example of how one folder is after use.
-rw-rwx—+ 1 laura@xxxx.local domain users@xxxx.local 109056 9 feb 17.52 PA255.xls
-rw-rw----+ 1 root domain admins@xxxx.local 378880 24 feb 2023 PA256.xls
-rw-rw----+ 1 root domain admins@xxxx.local 67584 2 nov 2022 PA259.xls
-rw-rw----+ 1 root domain admins@xxxx.local 67072 2 nov 2022 PA271.xls
-rw-rwx—+ 1 ufficiotecnico@xxxx.local domain users@xxxx.local 760832 13 feb 12.22 PA273.xls
-rw-rw----+ 1 root domain admins@xxxx.local 79360 2 nov 2022 PA323.xls
-rw-rw----+ 1 root domain admins@xxxx.local 120832 2 nov 2022 PA329.xls
-rw-rw----+ 1 root domain admins@xxxx.local 121344 2 nov 2022 PA356.xls
-rw-rw----+ 1 root domain admins@xxxx.local 80896 15 dic 2022 PA407.xls
After a permission reassignment on share everythings come back to work fine, till some user made changes again.
-rw-rw----+ 1 root domain admins@xxxx.local 109056 9 feb 17.52 PA255.xls
-rw-rw----+ 1 root domain admins@xxxx.local 760832 13 feb 12.22 PA273.xls
Any Idea ?
It seems that this issue comes when user switch from libreoffice to msoffice 2021.
The ending + denotes the presence of an extended ACL. Could you list its contents with getfacl? E.g.
getfacl -R .
Hi davide, thanks for reply.
This is the output
file: Recycle Bin/SCHEDE/RACHEL/Copy #16 of .~lock.SH258 .xls#
owner: root
group: domain\040admins@xxxx.local
user::rw-
user:denise@xxxx.local:rw-
user:fabio@xxxx.local:rw-
user:schede@xxxx.local:rw-
user:portatile@xxxx.local:rw-
user:ufficiotecnico@xxxx.local:rw-
user:controlloq@xxxx.local:rw-
user:laura@xxxx.local:rw-
user:isabella@xxxx.local:rw-
user:rs@xxxx.local:rw-
user:nicole@xxxx.local:rw-
user:marzia@xxxx.local:rw-
user:genny@xxxx.local:rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #17 of .~lock.SH258 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #18 of .~lock.SH258 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #19 of .~lock.SH258 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #20 of .~lock.SH258 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #8 of .~lock.SH242 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #21 of .~lock.SH258 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #22 of .~lock.SH258 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #9 of .~lock.SH242 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #23 of .~lock.SH258 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #24 of .~lock.SH258 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #1 of .~lock.BR 496.xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #2 of .~lock.BR 496.xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #3 of .~lock.BR 496.xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #10 of .~lock.SH242 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #11 of .~lock.SH242 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #12 of .~lock.SH242 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #13 of .~lock.SH242 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/PA251 S .xls
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/.~lock.PA251 S .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #1 of .~lock.PA238 CM40.xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #2 of .~lock.PA238 CM40.xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #1 of .~lock.PA251 S .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #2 of .~lock.PA251 S .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #3 of .~lock.PA238 CM40.xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/.~lock.BR502 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #4 of .~lock.BR 496.xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #1 of .~lock.BR502 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #2 of .~lock.BR502 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #3 of .~lock.BR502 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #4 of .~lock.BR502 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #25 of .~lock.SH258 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #26 of .~lock.SH258 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #5 of .~lock.BR502 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #27 of .~lock.SH258 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #6 of .~lock.BR502 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #7 of .~lock.BR502 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #28 of .~lock.SH258 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #29 of .~lock.SH258 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #3 of .~lock.PA251 S .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #4 of .~lock.PA238 CM40.xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #30 of .~lock.SH258 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #31 of .~lock.SH258 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #4 of .~lock.PA251 S .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #5 of .~lock.PA251 S .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #32 of .~lock.SH258 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #33 of .~lock.SH258 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #34 of .~lock.SH258 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #35 of .~lock.SH258 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #36 of .~lock.SH258 .xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #5 of .~lock.PA238 CM40.xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #6 of .~lock.PA238 CM40.xls#
owner: root
user::rw-
group::rw-
mask::rw-
other::—
file: Recycle Bin/SCHEDE/RACHEL/Copy #8 of .~lock.BR502 .xls#
owner: root
user::rw-
user:cont
