Hello,
can I modify /etc/postfix/main.cf to employ a sender dependant authentication to the smarthost? In case of the host where I want to relay email doesn’t accept mismatched sender?
BR
Stefano
Hello,
BR
Stefano
This howto may help you:
main.cf is templated, so you may use custom templates to add custom config, else your changes will be overwritten.
http://docs.nethserver.org/projects/nethserver-devel/en/v7/templates.html
Thank you,
just what i was looking for…
