Neth7 7.6
Hi everyone, I don’t know shorewall, so I ask how to unlock this rule, I also don’t understand why a host of the same LAN is blocked on the 389 service.
Also to give access from br0 from any port I regiola I have to enter?
Thanks for the answer, I was hoping for a less articulated solution to add a simple filter rule. I don’t understand why this procedure cannot be done via GUI, it would be easier to create without errors. Anyway thanks .
Create a new firewall service for the port(s) you want to open. Then add a new firewall rule referencing the service in a rule to allow access to the firewall from the green (internal LAN) interface.
