SFTP through Proxy
NethServer Version: 7.9.2009
Module: Squid
I tried to connect via WinSCP through our proxy to an external server. Without proxy it works.
At WinSCP I set the proxy as HTTP proxy and get the following error:
Proxy Error 403 Forbidden
access.log recognized this (I replaced the IP):
[Thu Mar 11 12:46:44 2021] 0 Source_IP TCP_DENIED/403 3863 CONNECT Destination_IP:22 - HIER_NONE/- text/html
After that I tried to bypass the proxy. I created a firewall object with the destination IP and configured squid to use this object for bypass a specific destination, but this didn’t change anything.
Site information:
The proxy is manual without authentication.
Thanks in advance
@m.traeumner
Hi Michael
Squid Proxy, no matter if in NethServer or elsewhere, has a VERY limited list of ports which it will handle. Port 22 is NOT among the defaults!
Two NethServer classics will NOT work without a “fix”: Ports 980 and 9090…
Here are a few “tips” from my personal “Squid Cheat List”… :slight_smile:
Squid Proxy
Safe Ports
config setprop squid SafePorts 443,8089,8489,8443,8080,10000,10010,5001,5000,3000,980,9090,8083,8084,8085,9001,1880,8006,8007
signal-event nethserver-squid-save
Excluded Sites:
config setprop squid NoCache www.nethserver.org,www.google.com
Hope this helps!
Hi Andy,
thanks for your message, I’ve forgotten to write, I also made Port 22 to a safe SSL_Port. I did it with a custom template.
config shows:
acl SSL_ports port 22           # SFTP
Easier to use the built in command / template…
Squid SHOULD be able to handle SFTP (Not SSH as such), but i’m not sure about this.
I personally bypass my Proxy at home for SSH / SFTP access to my clients.
This should help:
Thanks again Andi,
bypass for SFTP would be ok for me, but it didn’t work. How do you realize it?
Thanks Michael
@m.traeumner
Hi Michael
For me, it’s very simple. SSH does not go through my Proxy, it goes directly out via Firewall.
Truth is, I am practically the only person at my clients using SSH… :slight_smile:
Both my IT Partners DO use SSH (one more, one less), but both don’t really know how to use Port forwarding over SSH, even though I’ve showed them more than once…
(And I’m not that bad a tutor/teacher!)…
I just got the first of my new server hardware today, so now I have to replace my older Proxmox…
Loads of work!
As soon as my network is ready again, I will be attempting using SSH Passthru on Squid/OPNsense and Squid/NethServer…
Thanks Andy,
I found the hint at this documentation. I had to make two entries at my config:
acl safe_ports port 22          # SFTP
I thought SSL_ports would be enough, but the other one is necessary too.
Michael
