NethServer Version: 7.9 Module: SSH, Samba Active Directory
When I using SFTP to connect to server, it’s always go to path /var/lib/nethserver/home/client1. I want to change default path to /var/lib/nethserver/ibay/myshare.
Is there any advice how do I fix it.
Thanks and Cheers, Chartree…
I found this file in home directory .bash_profile
if [ -f ~/.bashrc ]; then . ~/.bashrc fi
PATH=$PATH:$HOME/.local/bin:$HOME/bin
export PATH
And try try to modify path. but nothing change. Hey GURU Any idea for this,
Hi Pong,
It is a bit confusing you are talking about SFTP but I think you mean SSH.
Which client are you using to access the Nethserver?
