NethServer release 7.3.1611
Nextcloud 12.x
when I create a user in nethserver, it is automatically created in nextcloud. the user in nexscloud results with unlimited quota, how do I change the default quota to 5GB in nexscloud?
thank you
Nextcloud 12.x
thank you
On admin user screen left bottom side you have settings:
There the default quota is hidden:
How to unhide it?
thanks for all
it is work.
thanks
Oh, Tnx!
You need to go to settings first. Go to the A of admin, select settings. Then go to te lower left bottom.
Then you are not logged in as server admin. By default the login credentials for admin are user: admin password: Nethesis,1234
You are logged in as Nethserver admin, not as Nextcloud admin. Once logged in as Nextcloud admin, go to users and add the Nethserver admin to the admin group, so the Nethsever admin can manage Nextcloud.
HTH
thanks a lot
got the quota setting
