FYI this step is needed when something is wrong in cockpit in order to debug…now let me check
Sorry to be lazzy, no time to read the thread, your certificate is Letsencrypt or selfsigned (default of nethserver)
on line 50 of /usr/libexec/nethserver/api/system-settings/execute could you add -k for test purpose
- /usr/bin/curl smtp://$hostname:$port -v --connect-timeout 10 --max-time 10 --mail-from $username --mail-rcpt $username --user "$username:$password" $tls <<EOF
+ /usr/bin/curl smtp://$hostname:$port -v -k --connect-timeout 10 --max-time 10 --mail-from $username --mail-rcpt $username --user "$username:$password" $tls <<EOF
Suggesting to allow the setting (accept every certificate) with a checkbox.
Yes without certificate validation it works.
Edit!!!
It’s the selfsigned nethserver certificate.
I am so sorry to not have seen this thread before, sorry for the waste of energy but I was off some time for holidays and I must say I needed it
Lets make a github issue and fix this bug, thank a lot @m.traeumner
I have to thank you.
An other one than you have posted above?
You deserved it
the workflow is
create a github issue to determine the bug (We prefer to talk first on forum, then create the bug)
create a PR to fix the bug
ready to be verified … please go to github
Thanks @stephdl,
I will test on Monday, I’m not at work till then.
I think I have to do a
yum update --enablerepo=nethserver-testing
Is it right?
never please you could update something wrong
Either pick the url of the two files in the GH issues or here in this case
yum install http://packages.nethserver.org/nethserver/7.9.2009/testing/x86_64/Packages/nethserver-cockpit-1.10.0-1.4.g8228906.ns7.noarch.rpm http://packages.nethserver.org/nethserver/7.9.2009/testing/x86_64/Packages/nethserver-cockpit-lib-1.10.0-1.4.g8228906.ns7.noarch.rpm
or
yum install nethserver-cockpit-lib nethserver-cockpit --enablerepo=nethserver-testing
Hi @stephdl,
I installed the update with
and it works. Of course I deleted the -k entry at
before.
Thanks for your great help.
