I will test this right now!
I just followed the instructions (mostly) for the test. I already have existing groups in my remote LDAP/AD system with email addressâs configured with the attribute âmailPrimaryAddressâ
cn=SGVFR-INSTRUCTORS,ou=Groups,dc=sgvfr,dc=lan
I hope this isnât the problem, my AD/LDAP domain has always been sgvfr.lan
changing to sgvfr.com seems like a lot of work.
I also tried to email SGVFR-INSTRUCTORS@sgvfr.lan - it also bounced.
LDAP group I was testing with is SGVFR-INSTRUCTORS (instructors@sgvfr.com)
my first test I tried the email address, then realized i should have sent the message to the group instead⌠both bounced from the server with
<SGVFR-INSTRUCTORS@sgvfr.com>: host sparky.sgvfr.com[/var/run/dovecot/lmtp]
said: 550 5.1.1 <SGVFR-INSTRUCTORS@sgvfr.com> User doesn't exist:
SGVFR-INSTRUCTORS@sgvfr.com (in reply to RCPT TO command)
login as: root
root@sparky.sgvfr.com's password:
Last login: Sun Mar 3 19:46:06 2019 from 172.20.250.15
[root@sparky ~]# yum install --enablerepo nethserver-testing nethserver-mail-ser ver
* ce-base: mirror.cwcs.co.uk
* ce-extras: mirror.cwcs.co.uk
* ce-sclo-rh: mirror.cwcs.co.uk
* ce-sclo-sclo: mirror.cwcs.co.uk
* ce-updates: mirror.cwcs.co.uk
* epel: mirrors.kernel.org
* nethforge: mirror.nordest.systems
* nethserver-base: mirror.nordest.systems
* nethserver-updates: mirror.nordest.systems
nethserver-testing/7/x86_64/signature | 836 B 00:00
nethserver-testing/7/x86_64/signature | 2.9 kB 00:00 !!!
nethserver-testing/7/x86_64/primary_db | 129 kB 00:00
Resolving Dependencies
--> Running transaction check
---> Package nethserver-mail-server.noarch 0:2.4.5-1.ns7 will be updated
---> Package nethserver-mail-server.noarch 0:2.4.5-1.9.gd3d7cd1.ns7 will be an update
Dependencies Resolved
Package Arch Version Repository Size
Updating:
nethserver-mail-server noarch 2.4.5-1.9.gd3d7cd1.ns7 nethserver-testing 112 k
Transaction Summary
Upgrade 1 Package
Total download size: 112 k
Is this ok [y/d/N]: y
Downloading packages:
No Presto metadata available for nethserver-testing
nethserver-mail-server-2.4.5-1.9.gd3d7cd1.ns7.noarch.rpm | 112 kB 00:00:00
Running transaction test
Transaction test succeeded
Running transaction
Updating : nethserver-mail-server-2.4.5-1.9.gd3d7cd1.ns7.noarch 1/2
Cleanup : nethserver-mail-server-2.4.5-1.ns7.noarch 2/2
Verifying : nethserver-mail-server-2.4.5-1.9.gd3d7cd1.ns7.noarch 1/2
Verifying : nethserver-mail-server-2.4.5-1.ns7.noarch 2/2
Updated:
Complete!
[root@sparky ~]# db configuration setprop postfix DynamicGroupAlias enable
[root@sparky ~]# signal-event nethserver-mail-server-update
[root@sparky ~]# mail -s "Test Subject" instructors@sgvfr.com < /dev/null
Null message body; hope that's ok
[root@sparky ~]# mail -s "Test Subject" SGVFR-INSTRUCTORS@sgvfr.com < /dev/null
Question: Do I still need to configure a âmail aliasâ under Management>Email Addresses ??
Please let me know what logs I can provide, I will do everything I can to help troubleshoot.
That is ignored
In this case you have to define some address aliases, however the UI is still not ready to support this use case: you have to use the command line (see below
@amygos is checking if the â-â minus sign is a problem
Yes you have to add a mail alias. As said the UI canât do it by now, but you can do it with this command
db accounts set instructors@ pseudonym Access public Account SGVFR-INSTRUCTORS@sgvfr.lan Description Test-5725
signal-event nethserver-mail-server-save
Delete instructors@ if it already exists.
There was a typo in the test cases, the value of the prop DynamicGroupAlias must be set to enabled instead of enable, sorry @SGVFR
So you can enable the feature with:
db configuration setprop postfix DynamicGroupAlias enabledsignal-event nethserver-mail-server-update
This donât seem to be a problem
Great, I will try again.
Thanks !
Initial test did work⌠I am able to send email to SGVFR-INSTRUCTORS@sgvfr.com from the root accouunt.
When you say âthat is ignoredâ regarding the email address attribute on the groups does that mean we will have to manually (one time) configure the alias for each group we want as a contact? but it will dynamically update with users on the LDAP/AD server, right?
Thanks.
Looking great so far !!
Good news! ![]()
Yes, just once.
Exactly. Consider also that group changes are effective when sssd cache expires, for remote ad/ldap. We have to check the sssd docs for the actual timings
@davidep A button/signal event for ârefresh cache nowâ could lead to problems?
I think it can be useful if you are in a hurry. However I see it for the cockpit UI only.
Another thing we can do is decreasing the cache lifetime to 15 minutes.
chance of a cli command for the impatient people? Could there be an option for a realtime view of the current email address list in the cockpit / dashboard ? Iâm happy with a cli command also.
sss_cache --groups
More info: man sss_cache
itâs a nice idea
Found a bug : an user is not removed from a group after it has been deleted.
Reproduce : delete user (eg âtest1â) and send a mail to the group (eg âmailgroupâ).
You got an non delivery notification.
Did you run it?
sss_cache --groups
Oh ! No. Working after that. Didnât understood what it was about in the context of this discussion.
I didnât understood that sentence. When I tested I didnât create any alias of any sort - and thatâs the intended way of doing things from my point of view. What is that alias youâre talking about ?
It looks like it is the same for local AD.
Some people have a âdomain.lanâ (or similar) domain suffix: a private domain suffix. They need to configure an alias domain or a group mail alias address to deliver messages into usersâ mailboxes.
Thanks for the heads-up: this need to be checked.
Youâre welcome. Btw I mixed up things; on this particular machine weâre talking about a DC (simple LDAP).
Matt
PS / Did i say how GREAT this update was ?? It will save us hours of pain and encoding errors.
PS2 / Will the definitive version support import / conversion of existing aliases ?
hello Matteo, just wondering if there is anything else I can help test or check? Iâve added a couple aliasâs, which also do show in the current dashboard so I can see which ones I have created.
So far it is working great.
Anything else I can do, I would be happy to help with.
