Securing NS with Suricata and Threat Shields
NethServer Version: 7.8
Module: Suricata and Threat Shields
I’m trying to protect the internal LAN as much as possible…
I’m running Squid and it’s doing a fairly decent job. However, I would also like to implement Suricata and Threat Shields. But, when I enable all lists, it ruins the LAN access to the internet and even access to the Pilot (internal IP)
Is there a how-to or something similar to what lists to enable both for Suricata and Threat Shields?
Thanks
See the firehol blocklist documentation for choosing the right lists to enable.
I just use a basic set: Blocklist de, Dshield, Feodo, Spamhaus drop, Spamhaus edrop, Iblocklist abuse palevo, Sslbl, Zeus badips.
As regards suricata see the documentation to learn about the different rule categories.
I block following IPS rule categories, the others are set to alert:
BlockCategories=ET-botcc.portgrouped,ET-botcc,ET-ciarmy,ET-compromised,ET-drop,ET-dshield,ET-emerging-activex,ET-emerging-attack_response,ET-emerging-exploit,ET-emerging-malware,ET-emerging-netbios
To output your blocked categories just enter
config show suricata
in a terminal.
Huge Thanks Markus!
Will try to implement the recommendations tomorrow.
Will let you know how it goes!
Again, thanks!
Hi Markus,
Had the chance to implement as per your tips. It’s working and I feel grateful for your help!
I will be refining as much as possible as things/my understanding progresses
Thanks again
