A great feature would be to have the possibility to install seafile from the software center on a neth server.
When I build my first private cloud I tried owncloud but it was a nightmare and I had lots of problems. I guess it was with Version 3 or 4. Then after investigating further I found seafile and it worked well from beginning.
Seafile is build with git and in my opinion this is a much better approche to build a private file cloud as owncloud did with php (at least in the beginning, maybe they changed something after I droped it).
So I think it would add value to neth to integrate seafile.
Features are:
- File Storage
- Web interface (customizable)
- Sync client (win, linux, mac)
- webdav
- mobile client
- client based encryption
- sharing
For further information please check:
offitial website:
https://www.seafile.com/en/home/
offitial dokumentation:
http://manual.seafile.com/
support forum (english and german):
https://forum.seafile-server.org/
It is recommended to install seafile with nginx and mariadb or mysql. Additionally seafile should be configured to use https and either a self signed cert or one from an CA.
Hope to see it some time in neth
