Hello
I am fitting with SIP on Cisco Phons 7975G and 7970G. I will try move back Cico sccp protocol and a end point manager
I am following this small how to do
yum -y install git
cd /usr/src
git clone https://github.com/chan-sccp/chan-sccp chan-sccp_master
cd chan-sccp_master
./configure --enable-conference
but here is the end …
Checking Configure Options:
checking pkg-config asterisk... not found
checking Search Path: /usr /usr/local /opt... not-found
not-found
not-found
configure: Please install either the asterisk-devel package.
configure: Or run ./configure --with-asterisk=PATH with PATH pointing to the directory where you installed asterisk
configure: error: Cannot find pbx libraries - these are required.
What is the rigth path ?
sometimes its mutch esear to ask than to search to long
second one the phone get the configurations and the like PXE from an TFTP server. Thats easy and running 4 SIP. But it is better to know with option the DHCP server used. Wher ist de config file 4 DHCP services?
THX axel
