ok
the version 0.3 is officially out
you can download from here https://minucci.net/nethserver/nethserver-sambastatus-0.3-1.x86_64.rpm
now you can see a list of machines that are joined domain
I looked to you repository this morning
I think records inside the /var/lib/nethserver/db/accounts
are not really synchronized to the content of AD LDAP.
I think you need something like this:
net ads -P search '(objectCategory=Computer)' dnsHostName
If you want to know also the last login:
net ads -P search '(objectCategory=Computer)' dnsHostName lastLogonTimestamp
Edit: just a quick and dirt perl script which outputs data in JSON:
#!/usr/bin/perl
use JSON;
use POSIX;
my $output = qx(net ads -P search '(objectCategory=Computer)' cn dNSHostName lastLogonTimestamp);
my @machines;
my %current;
foreach my $line (split /[\r\n]+/, $output) {
if ($line =~ /^cn: (.*)/) {
if (%current) {
push(@machines,\%current);
%current = ();
$current{'cn'} = $1;
if ($line =~ /^dNSHostName: (.*)/) {
$current{'dNSHostName'} = $1;
if ($line =~ /^lastLogonTimestamp: (.*)/) {
$current{'lastLogonTimestamp'} = floor(($1/10000000)-11644473600);
print encode_json(\@machines);
i knew there was a better solution then mine
but
[root@server ~]# net ads -P search ‘(objectCategory=Computer)’ dnsHostName
ads_connect: No logon servers
[root@server ~]#
Mmm, I think you’re using NethServer 6.9. Am I right?
The proposed scripts works only NS 7 with Active Directory.
What is your scenario? Maybe I can try to create something which works on more environments.
yes, mine is 6.9
but i think i have some problem with ldap:
[root@server ~]# /etc/init.d/slapd start
Starting slapd: [FAILED]
[root@server ~]#
the log tell me
Oct 2 17:57:48 server slaptest: auxpropfunc error invalid parameter supplied
some time ago i fixed this bug i don’t remember how
IIRC in 6.9 slapd is handled by upstart, you need these commands:
status slapd
start slapd
stop slopd
Hello Carlo,
I installed your form on my NS7 but unfortunately it does not show anything!
smbstatus from the console displays this:
in the shell try
smbstatus -b
and
smbstatus -L
and past the output
but… do you use nethserver as domain controller or not?
mmm
ok… i don’t know why… I begin to investigate
Hi @gecco,
nice presentation at the conference.
I tried your module now on 7.3.1611 and like it happened to @netbix, my web UI also shows nothing.
[root@server ~]# smbstatus -b
Samba version 4.6.2
PID Username Group Machine Protocol Version Encryption Signing
9509 nobody nobody 192.168.1.228 (ipv4:192.168.1.228:2297) SMB2_10 - -
[root@server ~]# smbstatus -L
Locked files:
Pid Uid DenyMode Access R/W Oplock SharePath Name Time
9509 99 DENY_NONE 0x100080 RDONLY NONE /var/lib/nethserver/ibay/gast . Tue Oct 3 11:36:19 2017
9509 99 DENY_NONE 0x100081 RDONLY NONE /var/lib/nethserver/ibay/gast . Tue Oct 3 11:36:19 2017
Had a look at the command in /usr/share/nethesis/NethServer/Template/SambaStatus/Connection.php
[root@server SambaStatus]# smbstatus -b | sed -e '1,4d' | awk '{print $2 \"\t\" $4 \"\t\" $5}' | sort -h
awk: cmd. line:1: {print $2 \"\t\" $4 \"\t\" $5}
awk: cmd. line:1: ^ backslash not last character on line
awk: cmd. line:1: ^ syntax error
It seems to be the masking of the tabs so I tried the following:
[root@server SambaStatus]# smbstatus -b | sed -e '1,4d' | awk -v OFS="\t" '{print $2, $4, $5}' | sort -h
But on web UI I still see nothing.
this happen because in php you have to escape the "
in bash no
the right command is
smbstatus -b | sed -e ‘1,4d’ | awk ‘{print $2 “\t” $4 “\t” $5}’ | sort -h
machines added to domain what should i show?
/var/lib/nethserver/db/accounts ???
Tried this in the php:
$command = "smbstatus -b";
$admin_shell = shell_exec($command);
echo $admin_shell;
and got
mmm
yes… i think it is the problem… (srvmgr is the user run webserver)
in 7.3
[root@segreteria tmp]# su srvmgr
bash-4.2$ smbstatus -b
smbstatus only works as root!
bash-4.2$
in 6.9
[root@server tmp]# su srvmgr
[srvmgr@server tmp]$ smbstatus -b
Samba version 3.6.23-45.el6_9
PID Username Group Machine14913 admin admin (192.168.1.2)
9461 dimichele dimichele docenti3 (192.168.1.156)
14915 minucci minucci (192.168.1.2)
13254 giorgini giorgini docenti2 (192.168.1.155)
mmm… a big problem…
my sambastatus is not ready for nethserver 7
Did a very dirty trick, just writing smbstatus to a file as root:
[root@server SambaStatus]# su - srvmgr
Creating home directory for srvmgr.
[root@server SambaStatus]# smbstatus -b > home/svrmgr/smbstatb
Replaced the command string in Connection.php with:
$command = "cat ~/smbstatb | sed -e '1,4d' | awk '{print $2 \"\t\" $4 \"\t\" $5}' | sort -h";
Maybe let a cron job write the smbstatus to the file?
Somethings wrong with “Host name” which shows “users@cmb.local” but maybe I changed something when trying to find the error.
Hi Markus,
can you try $command = “sudo smbstatus -b”;
You can check that smbstatus is able to be run as sudo ?
i tried… but ask for password
