Absolutely great! Your little module becomes a project itself… I love it!
It’s great, @davidep how can @gecco improve it permitting string translations by transifex?
I’d like to see it in English and make it worldwide!
it’s in english and in italian, i make two different file:
[root@server Language]# pwd
/usr/share/nethesis/NethServer/Language
[root@server Language]# find ./ -iname SambaStatus
./it/NethServer_Module_SambaStatus.php
./en/NethServer_Module_SambaStatus.php
i think it is sufficient… or not?
Well, English was enough
…because other languages are translated on Transifex.
To prepare your code for localization, a GitHub repository would help me on uploading the source strings to Transifex. Could you share your code on GitHub?
For more details:
http://docs.nethserver.org/projects/nethserver-devel/en/v7b/i18n.html
i don’t know nothing about nethgui way, where i can found some documentation?
Have a look at
http://docs.nethserver.org/projects/nethserver-devel/en/v7b/create_interface_module.html
do you call it documentations?
Feel free to try and follw those directions and extend the documentation with the information you come across. I am sure @davidep will help you with any step you have trouble with… ![]()
first step:
There is some deprecated documentation in github’s nethgui, maybe some points are still valid (@davidep?)
Also different components in use, like Mustache, jquery, datatables…
Just say it because I wasted some time looking at symfony and twig just to find out mustache was used for templates.
What are you referring to? Could you make some examples?
@gecco Your commits comments are great!!!
just wondering if the docs (Programmer Guide, and the User Interface guidelines) can be of use, like the module dissection in the Programmer Guide.
this is a screenshot of new version…
but… somebody can help me? i can’t understand how work the \Nethgui\Controller\TableController
What is your goal?
TableController may help you if every row represents something on which a set of action can be executed. However, if you just want to display a table, it is not worth a dime.
ok but where can i read some documentation about this?
I know the answer but I’m afraid you don’t want to know it.
Any Italian guy can help me with that? Translating Gecco’s notes?
When I know and test Nethserver, this was the one feature that I miss from w2k.
Thank you for your effort Gecco.
@gecco did you upload that on NethForge? Do you need some help?
