gerald_FS
(Gerald)
December 27, 2016, 4:17pm
1
I have a problem with the Sambafreigageben and name resolutions in the local network.
I’m not sure where the error can be - DNS - SSSD - SAMBA ???
Sympthome:
Partly no connection to the release is possible.
\\jagerbox\ablage - registration not possible
\\192.168.5.10\ablage - registration possible
Approach of the virtual server with name resolution possible.
https://jagerbox.domain.lan/SOGo
Furthermore, I have problems that the directories are not writable, although the releases are set accordingly and has worked several days.
There are no entries in the log files samba as well as sshd …
greetings
enzoturri
(Vincenzo Turri)
December 27, 2016, 7:19pm
2
Hi @gerald_FS
Some questions:
The server is real or virtual?
Nethserver is configured as a domain?
gerald_FS
(Gerald)
December 27, 2016, 7:27pm
3
Yes it is a real server, and it is set up as Samba DC with its own domain.
The name resolution also works, except for the file release …
enzoturri
(Vincenzo Turri)
December 27, 2016, 7:49pm
4
I’m no expert (usually use windows DC).
During the tests I had similar problems. Once the sssd service had not started, once the dhcp had not passed the proper dns
If you run only
\\jagerbox
Nethserver shows you your shares?
Perhaps @flatspin can help you
gerald_FS
(Gerald)
December 27, 2016, 8:08pm
5
No, no releases are displayed.
Even if I want to manually integrate it is only with the IP address.
No service has been terminated.
If I integrate you with the ip address does not work all the file right …
SSSD -ok
NSDC -ok
SMB -ok
DNS & DHCP - ok (the addresses are also assigned correctly by the DHCP service)
gerald_FS
(Gerald)
December 29, 2016, 11:07am
6
The problem is solved!
The system or I was lost when the network interfaces were rolled up.
Therefore, two red interfaces were defined and not green.
In the GUI it was correct but they have behaved wrong.
Once reinstallation and then went again - all interfaces reconfigured and it went.
Gerald
enzoturri
(Vincenzo Turri)
December 30, 2016, 6:01pm
7
Thank you for your feedback @gerald_FS
