NethServer Version: 7
hi,
I try to configure ufdbguard so that it activates the safesearch function. If the sites are blocked correctly, the search for images with google is not …
I’ve modified the ufdbguard.conf file to include the “safe-search on” value, but it does not work.
Last thing, if I restart the Netheserver, I am obliged to disable the proxy and then reactivate it so that the filter works again …
An idea for the safesearch function?
thank you.
