S20nethserver-duc-index #1 (exit status 256)
NethServer Version: 7.4
Hello,
I got this Error, if try to use Disk Usage–>Update.
These articles couldn’t help me:
Any hints vor me?
Regards, Marko
Ps.:
[root@nethserver /]# df -h
Dateisystem                        Größe Benutzt Verf. Verw% Eingehängt auf
devtmpfs                            3,9G       0  3,9G    0% /dev
tmpfs                               3,9G    153M  3,7G    4% /run
tmpfs                               3,9G       0  3,9G    0% /sys/fs/cgroup
/dev/mapper/centos_nethserver-root   50G    4,0G   47G    8% /
/dev/sda1                          1014M    252M  763M   25% /boot
/dev/mapper/centos_nethserver-home   35G     33M   35G    1% /home
192.168.2.2:/volume1/Daten          7,0T    4,0T  3,1T   57% /mnt/nfs/Synology-Daten
/dev/sdb1                           3,8G     16M  3,6G    1% /mnt/backup
[root@nethserver /]# lsblk
NAME                       MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
sdb                          8:16   1  3,9G  0 disk
└─sdb1                       8:17   1  3,9G  0 part /mnt/backup
sda                          8:0    0 93,2G  0 disk
├─sda2                       8:2    0 92,2G  0 part
│ ├─centos_nethserver-swap 253:1    0  7,8G  0 lvm  [SWAP]
│ ├─centos_nethserver-home 253:2    0 34,4G  0 lvm  /home
│ └─centos_nethserver-root 253:0    0   50G  0 lvm  /
└─sda1                       8:1    0    1G  0 part /boot
What do you see at
/var/log/messages
after you tried to update?
Hi Michael,
the updates was finished 13:53:31
After this point came such messages:
Mar 12 10:55:54 nethserver dracut: dracut module ‘modsign’ will not be installed, because command ‘keyctl’ could not be found!
Mar 12 10:55:54 nethserver dracut: dracut module ‘busybox’ will not be installed, because command ‘busybox’ could not be found!
Mar 12 10:55:55 nethserver dracut: dracut module ‘ifcfg’ will not be installed, because it’s in the list to be omitted!
Mar 12 10:55:55 nethserver dracut: dracut module ‘plymouth’ will not be installed, because it’s in the list to be omitted!
Mar 12 10:55:55 nethserver dracut: dracut module ‘crypt’ will not be installed, because command ‘cryptsetup’ could not be found!
Mar 12 10:55:55 nethserver dracut: dracut module ‘dmraid’ will not be installed, because command ‘dmraid’ could not be found!
Mar 12 10:55:55 nethserver dracut: dracut module ‘mdraid’ will not be installed, because command ‘mdadm’ could not be found!
Mar 12 10:55:55 nethserver dracut: dracut module ‘multipath’ will not be installed, because command ‘multipath’ could not be found!
Mar 12 10:55:55 nethserver dracut: dracut module ‘cifs’ will not be installed, because command ‘mount.cifs’ could not be found!
Mar 12 10:55:55 nethserver dracut: dracut module ‘iscsi’ will not be installed, because command ‘iscsistart’ could not be found!
Mar 12 10:55:55 nethserver dracut: dracut module ‘iscsi’ will not be installed, because command ‘iscsi-iname’ could not be found!
Mar 12 10:55:55 nethserver dracut: 95nfs: Could not find any command of ‘rpcbind portmap’!
Mar 12 10:55:55 nethserver dracut: dracut module ‘resume’ will not be installed, because it’s in the list to be omitted!
Mar 12 10:55:56 nethserver dracut: dracut module ‘modsign’ will not be installed, because command ‘keyctl’ could not be found!
Mar 12 10:55:56 nethserver dracut: dracut module ‘busybox’ will not be installed, because command ‘busybox’ could not be found!
Mar 12 10:55:57 nethserver dracut: dracut module ‘crypt’ will not be installed, because command ‘cryptsetup’ could not be found!
Mar 12 10:55:57 nethserver dracut: dracut module ‘dmraid’ will not be installed, because command ‘dmraid’ could not be found!
Mar 12 10:55:57 nethserver dracut: dracut module ‘mdraid’ will not be installed, because command ‘mdadm’ could not be found!
Mar 12 10:55:57 nethserver dracut: dracut module ‘multipath’ will not be installed, because command ‘multipath’ could not be found!
Mar 12 10:55:58 nethserver dracut: dracut module ‘cifs’ will not be installed, because command ‘mount.cifs’ could not be found!
Mar 12 10:55:59 nethserver dracut: dracut module ‘iscsi’ will not be installed, because command ‘iscsistart’ could not be found!
Mar 12 10:55:59 nethserver dracut: dracut module ‘iscsi’ will not be installed, because command ‘iscsi-iname’ could not be found!
Mar 12 10:56:01 nethserver dracut: 95nfs: Could not find any command of ‘rpcbind portmap’!
The message block repeats every 5 minutes.
Hope it helps to find the failure.
best regards, Marko
These messages from dracut can be found on every system, they are “normal”.
But they appear when you update the kernel, not every 5 minutes. You can double check in /var/log/yum.log, you should find kernel at the same time.
@filippo_carletti
If I update the disk usage it looks like this:
Mar 20 09:13:50 groupware esmith::event[29983]: Event: nethserver-duc-save
Mar 20 09:13:56 groupware esmith::event[29983]: Action: /etc/e-smith/events/nethserver-duc-save/S20nethserver-duc-index SUCCESS [6.5072]
Mar 20 09:13:56 groupware esmith::event[29983]: Event: nethserver-duc-save SUCCESS
I don’t get the messages from dracut, but don’t know why.
@capote
Did you get some other errors before or after the dracat messages?
is that more relevant?
Mar 20 13:55:30 nethserver esmith::event[2647]: Event: nethserver-duc-save
Mar 20 13:55:32 nethserver esmith::event[2647]: fatal error: out of memory
Mar 20 13:55:33 nethserver esmith::event[2647]: Traceback (most recent call last):
Mar 20 13:55:33 nethserver esmith::event[2647]:  File "/usr/share/duc/xml2json.py", line 190, in <module>
Mar 20 13:55:33 nethserver esmith::event[2647]:    main()
Mar 20 13:55:33 nethserver esmith::event[2647]:  File "/usr/share/duc/xml2json.py", line 185, in main
Mar 20 13:55:33 nethserver esmith::event[2647]:    out = xml2json(input, options, strip_ns, strip)
Mar 20 13:55:33 nethserver esmith::event[2647]:  File "/usr/share/duc/xml2json.py", line 154, in xml2json
Mar 20 13:55:33 nethserver esmith::event[2647]:    return elem2json(elem, options, strip_ns=strip_ns, strip=strip)
Mar 20 13:55:33 nethserver esmith::event[2647]:  File "/usr/share/duc/xml2json.py", line 130, in elem2json
Mar 20 13:55:33 nethserver esmith::event[2647]:    child.attrib['size_actual'] = str(int(child.attrib['size_actual']) - size)
Mar 20 13:55:33 nethserver esmith::event[2647]: TypeError: unsupported operand type(s) for -: 'int' and 'NoneType'
Mar 20 13:55:33 nethserver esmith::event[2647]: Action: /etc/e-smith/events/nethserver-duc-save/S20nethserver-duc-index FAILED: 1 [2.481558]
Mar 20 13:55:33 nethserver esmith::event[2647]: Event: nethserver-duc-save FAILED
Yes! :slight_smile:
Do you have trillions of files?
Could you post the output of df -i ?
You’re funny…:rofl:
This is a pure NethServer installation without any productive data or parallel frameworks like group ware or office communication.
root@nethserver ~]# df -i
Dateisystem                          Inodes IBenutzt    IFrei IUse% Eingehängt auf
devtmpfs                             998296      444   997852    1% /dev
tmpfs                               1001599        1  1001598    1% /dev/shm
tmpfs                               1001599      560  1001039    1% /run
tmpfs                               1001599       17  1001582    1% /sys/fs/cgroup
/dev/mapper/centos_nethserver-root 26214400    91597 26122803    1% /
/dev/sda1                            524288      350   523938    1% /boot
/dev/mapper/centos_nethserver-home 18036736        7 18036729    1% /home
192.168.2.2:/volume1/Daten                0        0        0     - /mnt/nfs/Synology-Daten
tmpfs                               1001599        1  1001598    1% /run/user/0
/dev/sdb1                            253952       28   253924    1% /mnt/backup
    [root@nethserver ~]# lsblk
I never experienced out of memory problems with duc, it was a shot in the dark.
Now I will focus on that NFS mount. Maybe duc has problems with it. Could you temporarily umount it and run duc?
Run it as below:
bash -x /etc/e-smith/events/actions/nethserver-restore-data-duc-index
Thank you for this try. But it doesn’t change anything, same again.
Mar 20 17:36:41 nethserver esmith::event[15166]: Traceback (most recent call last):
Mar 20 17:36:41 nethserver esmith::event[15166]:  File "/usr/share/duc/xml2json.py", line 190, in <module>
Mar 20 17:36:41 nethserver esmith::event[15166]:    main()
Mar 20 17:36:41 nethserver esmith::event[15166]:  File "/usr/share/duc/xml2json.py", line 185, in main
Mar 20 17:36:41 nethserver esmith::event[15166]:    out = xml2json(input, options, strip_ns, strip)
Mar 20 17:36:41 nethserver esmith::event[15166]:  File "/usr/share/duc/xml2json.py", line 154, in xml2json
Mar 20 17:36:41 nethserver esmith::event[15166]:    return elem2json(elem, options, strip_ns=strip_ns, strip=strip)
Mar 20 17:36:41 nethserver esmith::event[15166]:  File "/usr/share/duc/xml2json.py", line 130, in elem2json
Mar 20 17:36:41 nethserver esmith::event[15166]:    child.attrib['size_actual'] = str(int(child.attrib['size_actual']) - size)
Mar 20 17:36:41 nethserver esmith::event[15166]: TypeError: unsupported operand type(s) for -: 'int' and 'NoneType'
Mar 20 17:36:41 nethserver esmith::event[15166]: Action: /etc/e-smith/events/nethserver-duc-save/S20nethserver-duc-index FAILED: 1 [0.576666]
@filippo_carletti: This massiv increasing of memory using is related with starting the backup process.
today again…
best regards, Marko
Unfortunately, the problem is not reproducible, it seems to be something related to your system.
With the right expertise, I think it can be discovered, but, as I said, I have no past experience (duc just works).
Could you upload the content of /var/cache/restore/ in an archive somewhere?
Thank you for your commitment.
There you can download the file: https://whisp.ly/r/1lyHBWv#Owhtjt9sDPQ0i
best regards, Marko
