Hello,
I completed the migration from NS7, but Roundcube/Webmail was not an option (possibly I was running different version).
I already exported the database from NS7 and uploaded it to NS8, chowned to roundcubemail1:roundcubemail1.
But I cannot figure out how to call mysql command inside the container (especially as it is mariadb). I am a noob for containers, for sure.
First try was the following, with many others later…
runagent -m roundcubemail1 mysql roundcubemail < /home/roundcubemail1/.local/share/containers/storage/volumes/html/_data/roundcubemail.db -u roundcubemail -p
The error is usually:
File "/usr/local/bin/runagent", line 112, in <module>
os.execvp(args.COMMAND, [args.COMMAND] + args.ARGS)
File "<frozen os>", line 574, in execvp
File "<frozen os>", line 616, in _execvpe
File "<frozen os>", line 607, in _execvpe
FileNotFoundError: [Errno 2] No such file or directory
Which is I believe due to not finding the mysql command.
I guess I am not far from getting it working, but I cannot get it done.
How could I run mysql command inside roudcube1?
Thank you for your help in advance!
