alextunschi
(Alexandru Tunschi)
March 12, 2021, 9:43am
1
NethServer Version: 7.9.2009
I cannot start rsyslog: it gives me the following error:
" Error
dns.service_action_error
The following command has failed:
system-services/update"
I get the same error when I want to Enable/Start clamd.
Any ideas on how to get around this and what is causing it?
Thank you!
stephdl
(Stéphane de Labrusse)
March 13, 2021, 8:05pm
2
what is the output of
systemctl restart rsyslog
systemctl status rsyslog
alextunschi
(Alexandru Tunschi)
March 15, 2021, 6:01am
3
[root@server ~]# systemctl restart rsyslog
Job for rsyslog.service failed because the control process exited with error code. See “systemctl status rsyslog.service” and “journalctl -xe” for details.
[root@server ~]#
[root@server ~]# systemctl status rsyslog
● rsyslog.service - System Logging Service
Loaded: loaded (/usr/lib/systemd/system/rsyslog.service; enabled; vendor preset: enabled)
Active: failed (Result: start-limit) since Mon 2021-03-15 07:53:20 EET; 4s ago
Docs: man:rsyslogd(8)
http://www.rsyslog.com/doc/
Process: 8019 ExecStart=/usr/sbin/rsyslogd -n $SYSLOGD_OPTIONS (code=exited, status=1/FAILURE)
Main PID: 8019 (code=exited, status=1/FAILURE)
Mar 15 07:53:20 myserver.com systemd[1]: Failed to start System Logging Service.
Mar 15 07:53:20 myserver.com systemd[1]: Unit rsyslog.service entered failed state.
Mar 15 07:53:20 myserver.com systemd[1]: rsyslog.service failed.
Mar 15 07:53:20 myserver.com systemd[1]: rsyslog.service holdoff time over, scheduling restart.
Mar 15 07:53:20 myserver.com systemd[1]: Stopped System Logging Service.
Mar 15 07:53:20 myserver.com systemd[1]: start request repeated too quickly for rsyslog.service
[root@server ~]# journalctl -xe
– The result is failed.
– Subject: Unit rsyslog.service has finished shutting down
– Defined-By: systemd
– Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
– Unit rsyslog.service has finished shutting down.
Mar 15 07:53:20 myserver.com systemd[1]: Starting System Logging Service…
– Subject: Unit rsyslog.service has begun start-up
– Unit rsyslog.service has begun starting up.
Mar 15 07:53:20 myserver.com systemd[1]: rsyslog.service: main process exited, code=exited, status=1/FAILURE
– Subject: Unit rsyslog.service has failed
– Unit rsyslog.service has failed.
Mar 15 07:53:31 myserver.com kernel: Shorewall:net2fw:DROP:IN=enp2s0 OUT= MAC=40:3f:8c:b1:ad:2d:cc:e1:7f:74:48:20:08:00 SRC=185.156.73.19 DST=x.x.x.x LEN=40 TOS=0x00 PREC=0x00 TTL=250 ID=53797 PROTO=TCP SPT=59850 DPT=572 WINDOW=1024 RES=0x00 SYN URGP=0
Mar 15 07:53:35 myserver.com kernel: Shorewall:net2fw:DROP:IN=enp2s0 OUT= MAC=40:3f:8c:b1:ad:2d:cc:e1:7f:74:48:20:08:00 SRC=144.76.137.80 DST=x.x.x.x LEN=1500 TOS=0x00 PREC=0x00 TTL=57 ID=6037 DF PROTO=TCP SPT=443 DPT=50849 WINDOW=260 RES=0x00 ACK URGP=0
Mar 15 07:53:35 myserver.com kernel: Shorewall:net2fw:DROP:IN=enp2s0 OUT= MAC=40:3f:8c:b1:ad:2d:cc:e1:7f:74:48:20:08:00 SRC=144.76.137.80 DST=x.x.x.x LEN=1500 TOS=0x00 PREC=0x00 TTL=57 ID=3513 DF PROTO=TCP SPT=443 DPT=50851 WINDOW=260 RES=0x00 ACK URGP=0
Mar 15 07:53:35 myserver.com dnsmasq-dhcp[1469]: DHCPREQUEST(enp3s0) 192.168.6.217 1c:b7:96:41:b6:b8
Mar 15 07:53:35 myserver.com dnsmasq-dhcp[1469]: DHCPACK(enp3s0) 192.168.6.217 1c:b7:96:41:b6:b8 HUAWEI_P30_Pro-c0e84155a0
Mar 15 07:53:37 myserver.com kernel: Shorewall:net2fw:DROP:IN=enp2s0 OUT= MAC=40:3f:8c:b1:ad:2d:cc:e1:7f:74:48:20:08:00 SRC=185.236.11.31 DST=x.x.x.x LEN=40 TOS=0x00 PREC=0x00 TTL=249 ID=13028 PROTO=TCP SPT=47542 DPT=6960 WINDOW=1024 RES=0x00 SYN URGP=0
Mar 15 07:53:45 myserver.com kernel: ndpi_net_exit:ns20
Mar 15 07:53:45 myserver.com dnsmasq-dhcp[1469]: DHCPREQUEST(enp3s0) 192.168.6.28 f8:c3:9e:c4:dc:82
Mar 15 07:53:45 myserver.com dnsmasq-dhcp[1469]: DHCPACK(enp3s0) 192.168.6.28 f8:c3:9e:c4:dc:82 HUAWEI_Mate_20_Pro-c1db80
lines 1147-1201/1201 (END)
stephdl
March 16, 2021, 11:52am
4
Check in messages log if you have more clues, for now we just know the UI is not broken, we just do not know why rsyslog does not restart
alextunschi
(Alexandru Tunschi)
March 16, 2021, 12:28pm
5
In logs I find only this:
CODE_FILE
src/core/job.c
CODE_FUNCTION
job_log_status_message
CODE_LINE
774
MESSAGE_ID
be02cf6855d2428ba40df7e9d022f03d
PRIORITY
3
RESULT
failed
SYSLOG_FACILITY
3
SYSLOG_IDENTIFIER
systemd
UNIT
rsyslog.service
_BOOT_ID
8f0c633ce5e840d48070426f618ee947
_CAP_EFFECTIVE
1fffffffff
_CMDLINE
/usr/lib/systemd/systemd --switched-root --system --deserialize 22
_COMM
systemd
_EXE
_GID
0
_HOSTNAME
myserver.com
_MACHINE_ID
0835150034214041b4f3f4345399ff29
_PID
1
_SOURCE_REALTIME_TIMESTAMP
1615896625673406
_SYSTEMD_CGROUP
_TRANSPORT
journal
_UID
0
__CURSOR
s=384c879f20a0466d9e307c504ccd0c17;i=16e2;b=8f0c633ce5e840d48070426f618ee947;m=cff3a449;t=5bda6405df7cc;x=ed6a081bd15f06d2
__MONOTONIC_TIMESTAMP
3488851017
__REALTIME_TIMESTAMP
1615896625674188
