soft reject is also called grey-listing. As @stephdl says, it will ask the sending smtp server to send again. In most cases the mail will be accepted after resending.
stephdl
(Stéphane de Labrusse)
Split this topic
#4
think you are right. We also use pop3-connector to get emails from smarthost.
Now I disabled spamd - service. But emails don’t come in - they stay on the smarthost.
Will wait till tomorrow
Good morning,
last night I disabled rspamd - no effect. 3…5 mails are “hanging” at the smarthost.
The rspamd statistics are looking “normal” - take a look
I don’t agree.
If I am consolidating a mailserver for different external email addresses, getmail still be useful for retrieve old stuff and “wrong messages” from the old emailboxes.
Therefore, greylisting should be still be provided for hosted email boxes and addresses on the server.
checked emails at smarthost - the email from 31.01.2020 stay there !
checked /var/log/mail.log and found only one line about this email (names are changed):
Jan 31 12:20:11 msrv rspamd[26880]: ; csession; rspamd_task_write_log: id: 0BD77A246CF70C44B8A90035533ADC4F020B2AF748@srvexchDB01.ikkclassic.local, ip: 127.0.0.1, from: emil.mueller@ikk-classic.de, (default: F (soft reject): [0.15/20.00] [SUBJ_ALL_CAPS(0.15){2;},MIME_GOOD(-0.10){multipart/mixed;multipart/alternative;text/plain;},RCVD_NO_TLS_LAST(0.10){},FROM_EQ_ENVFROM(0.00){},FROM_HAS_DN(0.00){},GENERIC_REPUTATION(0.00){-0.063842656585994;},HAS_ATTACHMENT(0.00){},HAS_XOIP(0.00){},MIME_TRACE(0.00){0:+;1:+;2:+;3:~;4:~;},PREVIOUSLY_DELIVERED(0.00){steffen.jacob@eds-systeme.de;},RCPT_COUNT_ONE(0.00){1;},RCVD_COUNT_THREE(0.00){4;},TO_DN_ALL(0.00){}]), len: 591623, time: 8023.068ms, dns req: 7, digest: <41f96f9674cbe608547867299d13c507>, mime_rcpts: muster.mann@firma.de, file: stdin, forced: soft reject “timeout processing message”; score=nan (set by task timeout) Jan 31 12:20:11 msrv rspamd[26880]: ; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 2 regexps matched, 184 regexps total, 94 regexps cached, 0B scanned using pcre, 17.70KiB scanned total Jan 31 12:20:11 msrv dovecot: lda(user01@eds.lan): sieve: msgid=0BD77A246CF70C44B8A90035533ADC4F020B2AF748@srvexchDB01.ikkclassic.local: marked message to be discarded if not explicitly delivered (discard action) Jan 31 12:20:11 msrv getmail: msg 497/497 (599418 bytes) msgid 000093425134513e from emil.mueller@ikk-classic.de delivered to MDA_external command dovecot-lda () Jan 31 12:20:20 msrv clamd[2729]: Database correctly reloaded (6895964 signatures)
Yesterday I stopped greylist with enable = false in /etc/rspamd/override.d/greylist.conf (new file created)
Since 02.02.2020 at 6 o’clock there “thousands” of this lines: Feb 2 06:54:24 msrv rspamd[11266]: ; map; http_map_error: error reading https://maps.rspamd.com/freemail/free.txt.zst(88.99.142.95:443): connection with http server terminated incorrectly: ssl connect error: ssl error: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed Feb 2 06:54:25 msrv rspamd[11266]: ; map; http_map_error: error reading https://maps.rspamd.com/freemail/disposable.txt.zst(88.99.142.95:443): connection with http server terminated incorrectly: ssl connect error: ssl error: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed
it is not under our control, maps.rspamd.com is not on our resources, either you had a network issue, or rspamd from upstream got an undetermined issue
for what I read, your email has been well soft-rejected
