Rspamd soft reject email with getMail (wbilger)
For me it has only been 1 hour at the end of the work day yesterday, and 3 hours today, but so far I have received no soft rejects or timeouts.
This is with
task_timout = 8s;
soft_reject_on_timeout = false;
Should I be setting soft_reject_on_timeout back to true as was the default?
soft_reject_on_timeout = true;
Also, in the ClamAV settings, should I re-check “ClamAV official signatures”? Even though @giacomo says that unchecked is the new default?
I probably won’t feel comfortable updating until outside of working hours after a backup, so will do later and can then test all weekend.
…and are there any timeouts in your logs?
Well, that modification should be automatically overwritten by the update, because /etc/rspamd/rspamd.conf is expanded by our template. Take it into consideration.
I suggest to keep it disabled. However to validate the bugfix I ask to re-enable them for a few hours, just to be sure the bug does not bite any more.
No problem! Thank you very much for your help!
first thought on getmail verification
 Feb  7 17:55:04 prometheus rspamd[31990]: <aad1be>; csession; rspamd_controller_check_password: allow unauthorized connection from a trusted IP 127.0.0.1
Feb  7 17:55:04 prometheus rspamd[31990]: <aad1be>; csession; rspamd_message_parse: loaded message; id: <10acb788-182b-4b2c-fcdb-a85adf159e66@chubbfrance.com>; queue-id: <undef>; size: 513806; checksum: <0ecb0f65a1407a86243c84f546feba97>
Feb  7 17:55:04 prometheus rspamd[31990]: <aad1be>; csession; rspamd_mime_part_detect_language: detected part language: fr
Feb  7 17:55:04 prometheus rspamd[31990]: <aad1be>; csession; spf_symbol_callback: skip SPF checks for local networks and authorized users
Feb  7 17:55:04 prometheus rspamd[31990]: <aad1be>; csession; dkim_symbol_callback: skip DKIM checks for local networks and authorized users
Feb  7 17:55:04 prometheus rspamd[31990]: <aad1be>; lua; dmarc.lua:572: skip DMARC checks for local networks and authorized users
Feb  7 17:55:04 prometheus rspamd[31990]: <aad1be>; lua; once_received.lua:98: Skipping once_received for authenticated user or local network
Feb  7 17:55:19 prometheus rspamd[31990]: <aad1be>; lua; clamav.lua:119: clamav: failed to scan, maximum retransmits exceed
Feb  7 17:55:19 prometheus rspamd[31990]: <aad1be>; lua; common.lua:107: clamav: result - FAILED with error: "failed to scan and retransmits exceed - score: 0"
Feb  7 17:55:19 prometheus rspamd[31990]: <aad1be>; csession; rspamd_add_passthrough_result: <10acb788-182b-4b2c-fcdb-a85adf159e66@chubbfrance.com>: set pre-result to 'soft reject' (no score): 'Cannot validate the message now. Try again later' from force_actions(1)
Feb  7 17:55:19 prometheus rspamd[31990]: <aad1be>; csession; rspamd_task_write_log: id: <10acb788-182b-4b2c-fcdb-a85adf159e66@chubbfrance.com>, ip: 127.0.0.1, from: <stephane.delabrusse@Chubbfrance.com>, (default: F (soft reject): [1.10/19.90] [DATE_IN_PAST(1.00){},MIME_BASE64_TEXT(0.10){},MIME_GOOD(-0.10){multipart/mixed;text/plain;},RCVD_NO_TLS_LAST(0.10){},CLAM_VIRUS_FAIL(0.00){failed to scan and retransmits exceed;},FORCE_ACTION_CLAM_VIRUS_FAIL(0.00){soft reject;},FROM_EQ_ENVFROM(0.00){},FROM_HAS_DN(0.00){},GENERIC_REPUTATION(0.00){-0.27631962925491;},HAS_ATTACHMENT(0.00){},HAS_XOIP(0.00){},MID_RHS_MATCH_FROM(0.00){},MIME_TRACE(0.00){0:+;1:+;2:~;},PREVIOUSLY_DELIVERED(0.00){stephane@de-labrusse.fr;},RCPT_COUNT_ONE(0.00){1;},RCVD_COUNT_FIVE(0.00){5;},TO_DN_EQ_ADDR_ALL(0.00){}]), len: 513806, time: 15007.822ms, dns req: 0, digest: <0ecb0f65a1407a86243c84f546feba97>, mime_rcpts: <stephane@de-labrusse.fr>, file: stdin, forced: soft reject "Cannot validate the message now. Try again later"; score=nan (set by force_actions)
Feb  7 17:55:19 prometheus rspamd[31990]: <aad1be>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 2 regexps matched, 184 regexps total, 94 regexps cached, 0B scanned using pcre, 3.82KiB scanned total
Feb  7 17:55:19 prometheus getmail: Filter error (filter Filter_external rspamc-getmail (allow_root_commands="False", arguments="('-i', '127.0.0.1', '--mime', '-t', '120', '-h', 'localhost:11334')", command="rspamc-getmail", exitcodes_drop="('99',)", exitcodes_keep="('0',)", group="_rspamd", ignore_header_shrinkage="False", ignore_stderr="False", path="/usr/bin/rspamc-getmail", unixfrom="False", user="_rspamd") returned 3 ()#012)
cc @davidep
verified @davidep
I will continue to test this, but with the updated installed, I have just 2 soft rejects so far this weekend, but both were actually delivered after a 5 minute delay. That is perfect if that is how it is supposed to work now. Here are the logs;
Feb 8 10:25:03 lrtserv-data rspamd[2939]: <07233a>; csession; rspamd_message_parse: loaded message; id: 0.0.B.D6B.1D5DE937034ABDE.0@suitepmta022079.emsmtp.us; queue-id: ; size: 168533; checksum: <2a71f21eb7c2cb1e84a315a4c3a2029c>
Feb 8 10:25:03 lrtserv-data rspamd[2939]: <07233a>; csession; rspamd_mime_part_detect_language: detected part language: en
Feb 8 10:25:03 lrtserv-data rspamd[2939]: <07233a>; csession; spf_symbol_callback: skip SPF checks for local networks and authorized users
Feb 8 10:25:03 lrtserv-data rspamd[2939]: <07233a>; csession; dkim_symbol_callback: skip DKIM checks for local networks and authorized users
Feb 8 10:25:03 lrtserv-data rspamd[2939]: <07233a>; lua; dmarc.lua:572: skip DMARC checks for local networks and authorized users
Feb 8 10:25:03 lrtserv-data rspamd[2939]: <07233a>; lua; once_received.lua:98: Skipping once_received for authenticated user or local network
Feb 8 10:25:03 lrtserv-data rspamd[2939]: <07233a>; csession; make_dns_request_task_common: stop resolving on reaching 64 requests
Feb 8 10:25:03 lrtserv-data clamd[3050]: Reading databases from /var/lib/clamav
Feb 8 10:25:18 lrtserv-data rspamd[2939]: <07233a>; lua; clamav.lua:119: clamav: failed to scan, maximum retransmits exceed
Feb 8 10:25:18 lrtserv-data rspamd[2939]: <07233a>; lua; common.lua:107: clamav: result - FAILED with error: “failed to scan and retransmits exceed - score: 0”
Feb 8 10:25:18 lrtserv-data rspamd[2939]: <07233a>; csession; rspamd_add_passthrough_result: 0.0.B.D6B.1D5DE937034ABDE.0@suitepmta022079.emsmtp.us: set pre-result to ‘soft reject’ (no score): ‘Cannot validate the message now. Try again later’ from force_actions(1)
Feb 8 10:25:18 lrtserv-data rspamd[2939]: <07233a>; csession; rspamd_task_write_log: id: 0.0.B.D6B.1D5DE937034ABDE.0@suitepmta022079.emsmtp.us, ip: 127.0.0.1, from: suite11@xpressus.emsmtp.us, (default: F (soft reject): [2.93/15.00] [SUBJECT_HAS_CURRENCY(1.00){},URI_COUNT_ODD(1.00){189;},R_PARTS_DIFFER(0.93){96.5%;},MIME_GOOD(-0.10){multipart/alternative;text/plain;},RCVD_NO_TLS_LAST(0.10){},HAS_LIST_UNSUB(-0.01){},XM_UA_NO_VERSION(0.01){},CLAM_VIRUS_FAIL(0.00){failed to scan and retransmits exceed;},FORCE_ACTION_CLAM_VIRUS_FAIL(0.00){soft reject;},FROM_HAS_DN(0.00){},FROM_NEQ_ENVFROM(0.00){postmaster@enews.cesdeals.com;suite11@xpressus.emsmtp.us;},GENERIC_REPUTATION(0.00){0.80253696185865;},HAS_DATA_URI(0.00){},MIME_TRACE(0.00){0:+;1:+;2:~;},PREVIOUSLY_DELIVERED(0.00){wayne@mydomain.com;},RCPT_COUNT_ONE(0.00){1;},RCVD_COUNT_THREE(0.00){3;},TO_DN_NONE(0.00){}]), len: 168533, time: 15321.156ms, dns req: 64, digest: <2a71f21eb7c2cb1e84a315a4c3a2029c>, mime_rcpts: wayne@mydomain.com, file: stdin, forced: soft reject “Cannot validate the message now. Try again later”; score=nan (set by force_actions)
Feb 8 10:25:18 lrtserv-data rspamd[2939]: <07233a>; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 6 regexps matched, 184 regexps total, 93 regexps cached, 0B scanned using pcre, 183.74KiB scanned total
Feb 8 10:25:18 lrtserv-data getmail: Filter error (filter Filter_external rspamc-getmail (allow_root_commands=“False”, arguments=“(‘-i’, ‘127.0.0.1’, ‘–mime’, ‘-t’, ‘120’, ‘-h’, ‘localhost:11334’)”, command=“rspamc-getmail”, exitcodes_drop=“(‘99’,)”, exitcodes_keep=“(‘0’,)”, group=“_rspamd”, ignore_header_shrinkage=“False”, ignore_stderr=“False”, path=“/usr/bin/rspamc-getmail”, unixfrom=“False”, user=“_rspamd”) returned 3 ()#012)
Feb 8 10:25:18 lrtserv-data getmail: msg 105/105 (170766 bytes) msgid 1580749373/128 from suite11@xpressus.emsmtp.us
Feb 8 10:25:18 lrtserv-data getmail: )
Feb 8 10:25:21 lrtserv-data clamd[3050]: Database correctly reloaded (6905731 signatures)
And, 5 minutes later
Feb 8 10:30:03 lrtserv-data rspamd[2939]: ; csession; rspamd_controller_check_password: allow unauthorized connection from a trusted IP 127.0.0.1
Feb 8 10:30:03 lrtserv-data rspamd[2939]: ; csession; rspamd_message_parse: loaded message; id: 0.0.B.D6B.1D5DE937034ABDE.0@suitepmta022079.emsmtp.us; queue-id: ; size: 168533; checksum: <2a71f21eb7c2cb1e84a315a4c3a2029c>
Feb 8 10:30:03 lrtserv-data rspamd[2939]: ; csession; rspamd_mime_part_detect_language: detected part language: en
Feb 8 10:30:03 lrtserv-data rspamd[2939]: ; csession; spf_symbol_callback: skip SPF checks for local networks and authorized users
Feb 8 10:30:03 lrtserv-data rspamd[2939]: ; csession; dkim_symbol_callback: skip DKIM checks for local networks and authorized users
Feb 8 10:30:03 lrtserv-data rspamd[2939]: ; lua; dmarc.lua:572: skip DMARC checks for local networks and authorized users
Feb 8 10:30:03 lrtserv-data rspamd[2939]: ; lua; once_received.lua:98: Skipping once_received for authenticated user or local network
Feb 8 10:30:03 lrtserv-data rspamd[2939]: ; csession; make_dns_request_task_common: stop resolving on reaching 64 requests
Feb 8 10:30:03 lrtserv-data rspamd[2939]: ; csession; rspamd_redis_connected: skip obtaining bayes tokens for BAYES_HAM of classifier bayes: not enough learns 114; 200 required
Feb 8 10:30:03 lrtserv-data rspamd[2939]: ; csession; rspamd_stat_classifiers_process: skip statistics as HAM class is missing
Feb 8 10:30:03 lrtserv-data rspamd[2939]: ; csession; rspamd_task_write_log: id: 0.0.B.D6B.1D5DE937034ABDE.0@suitepmta022079.emsmtp.us, ip: 127.0.0.1, from: suite11@xpressus.emsmtp.us, (default: F (no action): [2.93/15.00] [SUBJECT_HAS_CURRENCY(1.00){},URI_COUNT_ODD(1.00){189;},R_PARTS_DIFFER(0.93){96.5%;},MIME_GOOD(-0.10){multipart/alternative;text/plain;},RCVD_NO_TLS_LAST(0.10){},HAS_LIST_UNSUB(-0.01){},XM_UA_NO_VERSION(0.01){},FROM_HAS_DN(0.00){},FROM_NEQ_ENVFROM(0.00){postmaster@enews.cesdeals.com;suite11@xpressus.emsmtp.us;},GENERIC_REPUTATION(0.00){0.80253696185865;},HAS_DATA_URI(0.00){},MIME_TRACE(0.00){0:+;1:+;2:~;},PREVIOUSLY_DELIVERED(0.00){wayne@mydomain.com;},RCPT_COUNT_ONE(0.00){1;},RCVD_COUNT_THREE(0.00){3;},TO_DN_NONE(0.00){}]), len: 168533, time: 461.626ms, dns req: 64, digest: <2a71f21eb7c2cb1e84a315a4c3a2029c>, mime_rcpts: wayne@mydomain.com, file: stdin
Feb 8 10:30:03 lrtserv-data rspamd[2939]: ; csession; rspamd_protocol_http_reply: regexp statistics: 0 pcre regexps scanned, 6 regexps matched, 184 regexps total, 93 regexps cached, 0B scanned using pcre, 183.74KiB scanned total
Feb 8 10:30:05 lrtserv-data dovecot: lda(wayne@mydomain.com): sieve: msgid=0.0.B.D6B.1D5DE937034ABDE.0@suitepmta022079.emsmtp.us: stored mail into mailbox ‘INBOX’
Feb 8 10:30:05 lrtserv-data getmail: msg 105/105 (170766 bytes) msgid 1580749373/128 from suite11@xpressus.emsmtp.us delivered to MDA_external command dovecot-lda ()
This is the new behaviour, if clamd is not available, you soft reject the email but getmail receive an error and download it again
Fix released
Updates for NethServer 7.7.1908
@davidep @stephdl
Awesome job, thanks so much!
