Rspamd - MX_INVALID
NethServer Version: NethServer 7.9.2009
Module: RSpamD Version: 3.0
I’m stumbling over rspamd specifically about the question why/how the MX_INVALID (0.5) [] is determined by the system.
Feel free to test the domain ivbonline.de and leitz-schilder.de to see/check, if the mx is proper configured. Do I overlook something?
The config for rspamd shows
cat mx_check.conf
This file will be overwritten by the next rpm update
use /etc/rspamd/override.d/file.conf’ - to override the defaults
Set this to enable the module
enabled = true;
connection timeout in seconds
timeout = 1.0;
symbol yielded if no MX is connectable
symbol_bad_mx = “MX_INVALID”;
symbol yielded if no MX is found
symbol_no_mx = “MX_MISSING”;
symbol yielded if MX is connectable
symbol_good_mx = “MX_GOOD”;
lifetime of redis cache - 1 day by default
expire = 86400;
lifetime of redis cache for no valid mxes - 2 hours by default
expire_novalid = 7200;
greylist first message with invalid MX (require greylist plugin)
greylist_invalid = false;
prefix used for redis key
key_prefix = “rmx”;
It seems to me, the module is enabled.
From the cli of the server
dig @127.0.0.1 -p 10053 leitz-schilder.de
; <<>> DiG 9.11.4-P2-RedHat-9.11.4-26.P2.el7_9.8 <<>> @127.0.0.1 -p 10053 leitz-schilder.de
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 41614
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;leitz-schilder.de. IN A
;; ANSWER SECTION:
leitz-schilder.de. 95 IN A 130.180.19.2
;; Query time: 0 msec
;; SERVER: 127.0.0.1#10053(127.0.0.1)
;; WHEN: Sat Jan 29 02:28:25 CET 2022
;; MSG SIZE rcvd: 62
and
dig @127.0.0.1 -p 10053 mail.leitz-schilder.de
; <<>> DiG 9.11.4-P2-RedHat-9.11.4-26.P2.el7_9.8 <<>> @127.0.0.1 -p 10053 mail.leitz-schilder.de
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 5383
;mail.leitz-schilder.de. IN A
;; ANSWER SECTION:
mail.leitz-schilder.de. 52 IN A 130.180.19.2
;; WHEN: Sat Jan 29 02:29:08 CET 2022
;; MSG SIZE rcvd: 67
At this point, I’ve no idea where to investigate. Anybody jumping on?
Thanks for any help.
stefan
Don’t know why, it seems to work now. Maybe a temporary DNS issue…?
Sorry for the whistle.
