hucky
(kai)
August 11, 2022, 7:58am
1
NethServer Version: 7.9.2009
Module: rspamd
Hey Guys, i have a problem with the Spamfilter. I got a lot Messages what is Spam, but Rspamd dont recognize it as Spam. if i try to do the learn manually and let rspamd scan the message text, it recognize it as spam and would reject it. But if i then click upload i got a message all learn conditions denied learning spam in default classifier
09ec294b30a7a3cd2ef27e94153c338a@hostengines.com 127.0.0.1 support@hostengines.com []xxxxx@xxxxxxxxx.de Spende von 1,5 Millionen no action 0.00 / 226.26k 0.003 11.8.2022, 09:25:02
|undef|reject|30.40 / 22|0.180|11.8.2022, 09:27:15| | — | — | — | — | — | |Symbols
Sort by:|
BAYES_SPAM (19.999999) [99.99%]
MISSING_MID (8)
HFILTER_HOSTNAME_UNKNOWN (2.5)
MIME_GOOD (-0.1) [text/plain]
MISSING_FROM (0)
MISSING_DATE (0)
DMARC_NA (0) [No From header]
R_BAD_CTE_7BIT (0) [7bit]
MISSING_SUBJECT (0)
MISSING_TO (0)
RCVD_COUNT_ZERO (0) [0]
R_DKIM_NA (0)
MIME_TRACE (0) [0:+]
BROKEN_HEADERS (0)
Maybe someone has also this Problem?
mrmarkuz
(Markus Neuberger)
August 11, 2022, 8:05pm
2
hucky:
message text
I can’t reproduce the error. Did you paste the message source including headers?
There’s an open issue .
hucky
(kai)
August 12, 2022, 5:29am
3
Good Morning, if i put the raw message text in the scan field i got this 1914378490.2299228.T8LNAB61GMN9867Y4UR6@mail.googlegroups.com contains less tokens than required for bayes classifier: 4 < 11
mrmarkuz
(Markus Neuberger)
August 12, 2022, 8:22am
4
Please share a not working message or send it as PM.
hucky
(kai)
August 12, 2022, 9:06am
5
mrmarkuz
(Markus Neuberger)
August 12, 2022, 9:13am
6
I’d like to test it on my server so I’d prefer the raw source including headers.
hucky
(kai)
August 12, 2022, 10:04am
7
i send it
and i get it back because of
This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of its recipients. This is a permanent error.
The following address failed:
info@xxxx.yy :
SMTP error from remote server for GREETING command, host: mxlb.ispgateway.de (80.67.18.126) reason: 550-IP 82.165.159.39 is blacklisted (sbl.spamhaus.org ). Help at/Hilfe unte r
550 www.mfaq.info
mrmarkuz
(Markus Neuberger)
August 12, 2022, 10:13am
8
It seems your IP is on a spam blacklist.
For more details check following:
Check any IP, domain, or email in a blacklist. Just enter IP or Email domain to instantly check if IP exists in any of the 50+ anti-spam blacklist databases. It also shows proof of where the blacklist record of the given IP exists in the anti-spam...
Maybe you could use a smarthost as workaround?
hucky
(kai)
August 12, 2022, 10:20am
9
it is a smarthost from 1und1
mrmarkuz
(Markus Neuberger)
August 12, 2022, 10:47am
10
You may try to send directly without smarthost.
hucky
(kai)
August 12, 2022, 11:20am
11
i tried it now without smarthost
hucky
(kai)
August 12, 2022, 11:36am
12
was not possible without smarthost
mrmarkuz
(Markus Neuberger)
August 12, 2022, 11:49am
13
Did you get an error message?
If you want to use a smarthost, your provider needs to care about the blacklists.
Check out this wiki page for more details about the pros and cons of using a smarthost.
As regards the spam learning issue: Just send me the complete email message source text in a direct message so I can test it.
hucky
(kai)
August 12, 2022, 12:41pm
14
did it here, hope it is what you mean/need
mrmarkuz
(Markus Neuberger)
August 12, 2022, 12:59pm
15
Thanks, I could reproduce the error message but I think it can be ignored.
Please check if you enabled whitelisting, I found the following line in the message source:
X-Spam-Symbols: TO_WHITELIST
hucky
(kai)
August 12, 2022, 1:04pm
16
yes, its enabled. and i got a second ago again spam mails without recognizing it by rspamd
mrmarkuz
(Markus Neuberger)
August 12, 2022, 1:10pm
17
Whitelisting means that there’s no spam check so please disable whitelisting.
hucky
(kai)
August 12, 2022, 1:11pm
18
did it a second ago, now i will wait for next spam. thank you very much Markus.
hucky
(kai)
August 15, 2022, 7:17am
19
hey @mrmarkuz that was it, i disabled it, now it works. thank you very much. if i am next time in vienna, you got a scheiterhaufen from café diglas on my head
